Hardware tesselation
or
Steep parallax mapping
or both ^^
Features poll
Mesh Lights
Material Blending
Bump Maps
MLT
Material Blending
Bump Maps
MLT
Ubuntu 9.10 x64 | GTS 240 | 260.19.44 drivers | 3.0 Toolkit | Dual-Core 2.4 GHz | 4Gb| Blender 2.56a/latest Yoyoz plugin
WinXP32 | GTS 240 | 266.58 drivers | 3.0 Toolkit | Dual-Core 2.4 GHz | 4Gb | Blender 2.56a/latest Yoyoz plugin
- Alpha (Opacity) maps.
- Lights (emitting meshes).
- Bump maps.
- RGB Nor Maps.
- Volumetric light.
- Animation.
- A very useful (IMHO) and time saving thing would be display of the selected material in the right panel when clicking or overing an input triangle on the mesh node in the graph editor.
- Bump maps.
- RGB Nor Maps.
- Volumetric light.
- Animation.
Lets see whats most important ... some of them are already planned, i know
-Focus feature: draw a region and focus all gpu power on that area only, godspeed
Materials:
-(Hopefully) Fully featured material system, since it is the first step to be able to do the full range of phenomena on surfaces.
- day light for outdoor and portals for indoor, as well material based light.
-That includes different node types to work with(divide, multiply, ramp, etc...) , and more options to be able to tweak (fresnel factor, BRDF, absorption thickness, anisotropy, SSS, Dispersion, IoR values below 1, Luminosity,..), multiple shader layer...
-save those as custom settings or library
Camera:
- a realistic camera lens, including bokeh, dispersion and distortion. I even would love to see the possibility to be able to add a bumpmap or procedural scratch or dust approach on the lens itself.. that would be cool !
Output:
-Different render passes and formats like .hdr, .exr, spherical or longitude based panos, or maybe some baking to texture function.
-The feature to save the progress of the rendering, so you can continue later to render even further... if possible.
Scene:
- Node based scene assembling of multiple obj's and other components, custom groups/parent/child relationships.
That already is a lot but for the distant future:
- Animation starting with camera and lights as well as material attributes, later on complete character, baked/cached scenes ? Could be a memory hog
- Plugin based connection to other packages like Maya, Max, Modo, Softimage or many others..
- atmospheric phenomena, like fog and haze / volumetric procedurals... maybe someday even crazy volumetric voxel stuff like fumefx XD > this will require a few years until cards can munch those memory monster easily i guess..
Some improvements:
-A visible grid .. i know there is the button so its close.
-Axis indication and grid units per screen space (so you know the scene scale)
-Key to move and focus on object/scene, so camera will spin around that locations center, could also be picked manually (like in Zbrush local mode)
-Show nodes in collapsed mode first, way more overview !!!
-Currently node inspector is a little hard to view in the first moment, with the way it shows the values. I think this will become more artist friendly/ less programmer style by the time
-Prevent render viewport refresh by simply moving a node
-a small info picker for color and values of the framebuffer, maybe a histogram would be nice as well.
And finally
Eastereggs, cause every cool programm got those
Materials:
Camera:
Output:
Scene:
Some improvements:
And finally
WinXp x64 | Core2Quad 2,66 Ghz | 8GB Ram| Geforce 8800 GTX | CUDA 3.0
- joelegecko
1. alpha
2. bump
3. light emitting materials
2. bump
luchschen
My priorities
1-Resolution problem!!!!!
2-development of antialiasing filter
3-"invisible" HDR map
4-Bump map
5-to save materials (better materials library) as file
and yet, I would like to save the scene are no only in OCS format, but in OBJ too.
because sometimes you need to change the scene after setting up the materials and lighting.
4-Bump map
- Barry Convex
- Animation
- Antialiasing improvement
- Render passes (especially layers based on groups of objects and depth pass)
- Fresnel control
- Light emitting material
- SSS
- Ability to make the Hdr environment invisible
Talking about lights in Octane, will it be possible to move and transform the objects which will act as light sources or will we have to go back and forth between Octane and our 3D package?
Can't wait to see how the software will evolve, it's already impressive. Congrats.
- Fresnel control
- SSS
Win7 64 - Linux Mint 16 | Gigabyte Gtx760 4gb | Intel i7 3930k | 24gb Ram
