OctaneRender® 1.025 b2.55 test release [Obsolete]
pixelrush
Just to note I had an unusual event while trying out the chess set demo scene with sss
No idea what caused it but after playing with some setting and changing kernals a few times the window became unresponsive and I got a gpu 'failed' message where the memory use is shown below the 3d view.
Never had that before. When I looked at the memory use graphic in the preferences it was completely full.
I was amazed to see the octane process was taking maybe 600mb.
Actually all the memory used by each attribute might have about in the right proportion but was many times what should be. Serious memory leak or something? :geek: HTH
i7-3820 @4.3Ghz | 24gb | Win7pro-64
GTS 250 display + 2 x GTX 780 cuda| driver 331.65
Octane v1.55
radiance
Hi all,
We are going to release a small update, beta 2.55b tomorrow, fixing the linux/mac vertex problems,
and a handful of the other reported bugs.
We're building the releases, so if murphy's law does not show itself tomorrow, linux and mac users should be able to render propper SSS models during the weekend :)
Thanks for all the feedback, please keep posting whatever you may find, so we can inventorize and fix for next updates,
Radiance
ribrahomedesign
i had exactly the same problem then pixelrush, maybe its the latest nvidia driver ?
Rico
Windows 7 , 64 b / GTX 590 / Archicad 15 , 64 b / Cinema 4D R 13 studio , 64b /Intel(R)Core(TM)Extreme3,20Ghz /always latest Octane.
portgas
i don't really understand how to apply sss to my existing obj material. Any step-by-step instructions?) Thanks
Elvissuperstar007
Release 2.55 very long voxelization ! from 15-30 minutes
Mitsuma
I love the new SSS Material
portgas wrote:i don't really understand how to apply sss to my existing obj material. Any step-by-step instructions?) Thanks
http://refractivesoftware.com/forum/vie ... =21&t=9380
That helped me a lot.
evo
Hi everyone. I've got no problem everything work good!!
I've also try to make leave and grass...combining diffuse-sss + specular all on single surface mesh ad it work amaizing fast!!http://www.refractivesoftware.com/forum ... 5&start=10
Even courtain, single side mesh, works great with diffuse sss!!
http://www.refractivesoftware.com/forum ... =35&t=9355
Intel Core i7 920 @ 2.67GHz, 6.00 GB, 896 MBGeForce GTX 260 (x2), Windows
RIBS_stairs
http://www.refractivesoftware.com/forum ... =5&t=17973
telemmaite
evo, im not so sure that your results are great because of SSS. SSS needs a closed volume a geometry. Your leaves,grass and curtains are simple planes...the effect you are getting is mostly based on the material transmittance.
i5 2500K 4.7Ghz | Ram 4GB 1600mhz Kingston | Palit GTX 470 | Win7 64x | Octane with Blender 2.59
evo
Yes i know that sss it's a phisically phenomenon that, by definition, require a volume. Nature does not support single side geometry :D
But i found really good that in octane this node works fine and fast even for single side geometry. This is really important when we have to render a leaf without give it a proper volume. This is nice if you have 3000 leaves with 5 or more poligon each that become twice much.
So i like this results because a single node work fine also as a 2sidedmtl of vray o MR...but in a very much faster setup!!
RIBS_stairs
