FOR YOYOZ / BUG REPORT / linked instance groups crash
yoyoz
I can see the two spheres now in blender and they export fine to Octane. Please try your side with plugin v1.11 I posted a few minutes ago :-)
Now going for the particles... ;)
Desktop: Ubuntu 13.04 x64 - i7-3770K @ 3.5GHz - 32GB DDR3 - GTX670 2048MB
Laptop: Linux Mint 11 x64 - i7-2860QM @ 2.5GHz - 16GB DDR3 - Quadro 3000M 2GB
Software: NVidia 319.12 - Cuda 4.2.9 - Blender 2.66a
yoyoz
Particles also working, but you must add a 'ParticleInstance' modifier to the object that is the actual particle, and link the modifier to the object that is the PaticleSystem. Render option under the particle system is only for Blender's internal rendering. I played around a bit with your file, added 'hairs', flipped the normals on the emitter, added some randomness, etc... and attached the result back so you can have a look.
They don't look like hairs but this can be tweaked at the expense of insane memory and CPU usage :-)
tex-emit.blend.tar.gz
(162.11 KiB) Downloaded 333 times
matej
Yes the linked group now exports without problems in 1.11. Solved!
And now I get it how to properly export PS. :D Solved!
Thank you for your work & help! It's much appreciated.
cgmo.net
kiwimage
WOOOOT !
Thank you Lionel, you rock !
Titan Black + GTX 580-3go / Win 7 pro 64 bits / C4DR14 with integrated plugin / Blender / Octane standalone /
website : http://www.kiwimage.com
Return to “Blender”
