OctaneRender® 1.025 b2.55 test release [Obsolete]
Zay
Hmm, seems that smoothing is broken. With 2.55 I have to manually enable smoothing to everything in the scene.
Jaberwocky
Zay wrote:Hmm, seems that smoothing is broken. With 2.55 I have to manually enable smoothing to everything in the scene.
That's odd. Mine seems to be on by default and working fine.
Zay
That's odd. Mine seems to be on by default and working fine.[/quote]
So far I have loaded 4 scenes, and smoothing is disabled in all scenes. Never happened before.
Jaberwocky
Ok
I've tried loading 3 old octane scenes. Smoothing is still on in all of them.
Have you tried playing with your smoothing settings in the Preference ?
radiance
Hi guys,
I have added the linux and Mac OS X archives on the downloads section in the first post in this thread.
We appreciate your help in testing these too, and the errors/bugs already reported by other users.
We're taking notes and will fix these issues for the next update,
Thanks again,
Radiance
pixelrush
Just wanted to note that so far I haven't seen any issues with the new voxellising code.
If it is needed for implementing instances seems fine to use.
The 10m face scene I used to test is composed of object duplicates so it will be interesting to see how the same is with instances.
Keep up the good work :)
i7-3820 @4.3Ghz | 24gb | Win7pro-64
GTS 250 display + 2 x GTX 780 cuda| driver 331.65
Octane v1.55
Inciner
It seems, that Diffuse SSS on Directlight is actual only for one-sided surfaces.
For closed surfaces - it is AOdist addiction for now.
That's the current system. And, maybe, it could be enough for directlight rendering ^^
Яussian engineer (AutoCAD+LISP/Blender 2.69/3dsmax/Mypaint/GIMP) | win7x64 + GT525m DELL || win8x64 16Gb RAM 2x GTX 770
tomas_p
Hi.
Quite big slowdown by PMC during longtime rendering.
The Ms/sec is still around the same value but the real adding of samples is slower and slower.
Win Vista 64 | Phenom II X4 905e |Gigabyte GTX690 and zotac Geforce GTX260 | 8GB
Synthercat
Daniel79 wrote:Maybe i wrong the setting o my leaves...can you hel me???
Whit the scattering node, my tree is darken that whitout the node! why?
Thanks a lot
GEZUS! That's the best 3D tree I've ever seen? Was it through a plugin? what about the textures? please tell me!!!
Linux Mint 19.3 | GTX-1080Ti | AMD FX-8320 (OCed 4.4GHz) | 16GB RAM
PeterCGS
Just wanted to say that you saved my butt this weekend! I had to render sugarcubes, and no matter what I tried they looked like white marble blocks.. After trying SSS on them.. Peeeerfect sugar!! I had to buy a extra license just for that hahaha
Thanx a bunch!
Win7, i7 980 Hexacore, 24GB RAM, 3xEVGA SC 670 GTX 4GB
