dark water
User avatar (Default)
merid888
hello i would like know how i can create a natural white water clear becouse mine is so dark i been used material livebd and is the same result
i add image, thank you for your read this profile
kubo
use the little trick of adding some opacity to the specular material of the water, for a bonus, use a texture mix in the opacity with a noise generator and put something like 0,9 and 0,6 in the values, play with the scale of the noise and you'll get fake caustics on the go.... ;)
Sportler
Also, your absorption is like 0.0001, which means that most of the light is absorbed after it has passed through 0.0001m of water, more accurately: 0.1mm of water, try increasing it ;)
GPU: 1x Nvidia RTX 3080 Ti
RAM: 64GB DDR4 3200MHz
CPU: 5950x
merid888
gracias kubo por tu comentario pero donde encuentro este ¿ noise generator ?
thank you sportler i will the change and i`ll upload image
regards
in the image of palms and water mirror i did this texture with the version 2.46 and i don't had problem just was an specular with the values 1.333 and nothing more i don't know why i can't do the same texture with 2.52 version
kubo
you were using an HDRI to light the scene in the first one, on the second one you are using the sun.
The noise, use a turbulence node attach it to the first slot on a mix texture node, and play with the other 2 values till it looks correct.
merid888
hi kubo is not an hdri is just the background white of the octanerender, none texture
i'll try using your comment
regards
kubo
well, doesn't matter if it's an HDRI or a white texture, same applies. The sun right now has a different aproach and as long as you don't do the opacity trick with it light won't go thru your objects.
merid888
thank you again kubo, you are so friendly i'll upload image to see the caustics in the water, how do you know much about this program ?
regards
merid888
i add image the first without sun and second with sun
i add water values too
i would like read some comments
thank you
gilfanovruslan
The Sun is very blue, but without the blue sun water in not blue :)
Win 7 x64 |gtx560ti 2gb | 2600K | 16gb | Google translator
Return to “Works In Progress”
