refraction in wrong direction in octane?
andi
I played around with dispersion and wanted to make a render of a colourful refractive software logo when I stepped on a problem.
It seems like that light rays are refracted in the wrong direction. At first I believed I must have done something wrong. But several tests seemed to approve that octane handles refraction wrong.
In the picture below the light rays should be bend down instead of up.
As material for the prism I used standard specular. I just cranked up dispersion and turned of reflection.
I would like to attach the .ocs file but it doesn't seem to work.
Software: | Octane 2.52 | Blender 2.5 | Linux Mint 11 64bit |
Hardware: | CPU Intel Core2 Duo E6750 2.66 GHz | RAM 4GB | Videocard GeForce GT 430 |
andi
It says "The extension ocs is not allowed."
Hm, I thought it is possible to attach an octane file to a post. Maybe someone knows how this can be done?
cornel
that an odd problem-
Are all of the prism´s normals facing outwards?
Have you choosen the correct index of refraction? Glass must be between 1.440 and 1.900
Win 7 x64 | GTX770 Phantom 2GB | Phenom II X6 3.2GHz | 16GB
telemmaite
Zip or Rar file should work.
i5 2500K 4.7Ghz | Ram 4GB 1600mhz Kingston | Palit GTX 470 | Win7 64x | Octane with Blender 2.59
andi
ok, that's embarrassing. The normals where pointing inside. Stupid me!
Thanks cornel for the quick help!
cornel
you`re welcome.
95% of all octane problems are caused by inverted normals or wrong scale. The remaining 5% are sitting in front of the monitor. :D
Jaberwocky
cornel wrote:you`re welcome.
Actually 3% is caused by sitting in front of a monitor.
The remaining 2% is Brain fade caused by a lack of strong black coffee ;)
steveps3
Nice model though, I wouldn't mind a copy of that to play with.
(OS) Windows 7(64)
andi
Now it looks like expected!
@steveps3: the model is quite simple but maybe the lamp is a bit tricky. Here you go.
refraction.zip
(82.43 KiB) Downloaded 198 times
steveps3
I've tried rendering a prism before but without any luck.
(OS) Windows 7(64)
