Hey,
Octane will support using multiple GPU's soon (in a few weeks),
without using or needing SLI.
So a double card like a GTX295 could be good.
you could start using it currently, use the 2nd card (sub-card of the dual card in one) for rendering,
and the first card for display, then you get a responsive display while rendering with octane...
then later on, you can use both when octane supports it.
Radiance
Nvidia FX 9800
THATS SO GREAT!
i have a question, how is it going to handle the Vram ? i mean is it goingo to create the scene twice (in each card´s memory) or is it gong to be distributed in both?
if not , could be this possible? (hope so
thanks
thanks
Portfolio: http://www.tres31.com/site/
http://www.flickr.com/photos/tres31/
sr2 mobo / dual Xeon E5620 3.2Ghz / geforce gtx 480 + geforce 580 3gb msi twin frozr III / 20gb RAM
I hope so too, but as far as I know, each GPU must have same scene and data.juan wrote:THATS SO GREAT!
if not , could be this possible? (hope so)
thanks
If not, data traffics between GPUs will make performance seriously down,
since band width of PCIe(2GB/sec(r/w)) is much lower than that of VRAM(90GB/sec).
c:\> bandwidthTest.exe
Running on......
device 0:GeForce GTX 295
Quick Mode
Host to Device Bandwidth for Pageable memory
Transfer Size (Bytes) Bandwidth(MB/s)
33554432 4908.7
Quick Mode
Device to Host Bandwidth for Pageable memory
33554432 4860.2
Quick Mode
Device to Device Bandwidth
33554432 93794.1
&&&& Test PASSED
Press ENTER to exit...
Win7 64 | 2x XEON | 12GB | 8x GTX580
- MadMinstrel
As I understand it, both the cards need only the scene data. It would be nice to split the render target between them, which can get pretty large on a 12MP image.
Win 7 x64 | Geforce GTX295 | Quad 2.4GHz | 4GB
Yes, each GPU don't have to keep entire render target, I agree with you.MadMinstrel wrote:As I understand it, both the cards need only the scene data. It would be nice to split the render target between them, which can get pretty large on a 12MP image.
no, cuda does not use SLI.reberts2 wrote:So SLI will not be needed, utilized or valuable in an existing or future Octane setup?
Thanks.
SLI is only for directX and OpenGL games/apps.
Cuda uses the GPUs as separate processors much like multiple CPU cores.
So it can function with a mix of different GPUs and no SLI is needed.
Radiance
