OctaneRender® 1.025 beta 2.51 [OBSOLETE]
Draydin_r
Cool! Thanks for the responce! By the way I'm loving the speed increase, which seems to have sped up the render 2 fold.
Anyhow, thanks and looking forward to the next update!
Intel Core i7 CPU 6850K @ 3.60GHz 128.0 GB Ram / Win 10 64 bit / 1x GeForce RTX 3080
i've played a little with the new version in both osx 10.6.8 and win 7 and it seems very stable :)
absorption is fantastic :D
ciao beppe
Draydin_r
I've got to ask, is that a digital scan or a custom modeled skull? Eitherway it looks awesome!
acc24ex
sphere test
ROUBAL
Wow! I have not yet had time to test this release, but it looks very promising!
@Draydin_r:
the skull is a 3d reconstruction from a CT 64 (computer tomography) ;)
i think i've found a little bug :roll:
i usually create several nodes inside a macro expecially for emitters, one diffuse nodes with emission enabled and another without for fast switching the lights on and off.
now if i change the node connection to the macro out port, the rendering doesn't update, the only way is to change the kernel, obviously this doesn't happen with 1.246b
ciao beppe
afecelis
@Abstrax: I just sent you a pm with the obj file for testing. :D
Win10 Pro | Geforce GTX1070 8gb Vram X2 (display/render) | Intel Core I7 4770K 3.5GHz | 32GB DDR3 1600 Ram |Nvidia 378.78 drivers | Cuda 8.0 | Blender/Modo/Sketchup
ello
it happens very often that when i make adjustments to a material it doesnt update anymore. the renderer seems to not get aware of the changes unless i reload the file. anyone else having this problem?
cheers,
ello
win7,i5 760 6gb,gf 460 1gb
my cinema4d plugin collection for creating complex random or ordered structures and more: http://plugello.earthcontrol.de
abstrax
ello wrote:it happens very often that when i make adjustments to a material it doesnt update anymore. the renderer seems to not get aware of the changes unless i reload the file. anyone else having this problem?
cheers,
ello
Does it say "(failed)" in the viewport status bar?
Cheers,
Marcus
ello
abstrax wrote: Does it say "(failed)" in the viewport status bar?
no, it just doesnt do what it should. for example if i create a material macro and attach it to the mesh node. now doubleclick the macro and attach a diffuse material to it. thus far everything works. now i create a specular material for example and attach that to the macro and the renderer still renders the diffuse material.
