Camera export bug c4d 10 ?
beauphilippe
Hello, i don't know if is a bug but i try to export camera from C4D in octane render, but my view is not a same of cinema 4d
Can You help me ?
abstrax
Sorry, for the late reply. After Octane beta 2.5 I plan to release a small bug fix update for the C4D exporter. There have been 2 bugs in the camera export and one bug in the normal export (if the object doesn't have a phong tag).
To make sure that there are not more camera problems, could you please send the C4D scene to [email protected].
Thanks for your help,
Marcus
forbrand
the same problem. the view position in octane is far away from cinema 4d view than i push render from plugin
no problems here during the exporting of cameras, could you share a simple project that shows the issue, so we could try to look at it?
ciao beppe
forbrand
ciao beppe, no matter what scene it doesn't export properly camera position.
forbrand
maybe i have measure problems bitween octane and cinema 4d...
forbrand
problem solves when i select meters in scale units from octane OBJ Mesh import preferences, but leave centimeters in exporter from cinema 4d.
i'm glad to hear that you have solved :D
probably the issue comes from the new R13 unit system that can be a bit tricky :roll:
ciao beppe
