madasebrof wrote:I realized I just posted in the wrong place... just tested with 2.48b and some issues still apply:
1. Material picker is "flakier" in current build...
Previously, the material picker was rock-solid. Now, it often doesn't find a new material that is clearly on top of the previously selected material, or takes multiple clicks to find a new material.
2. The material list is no longer sorted from closest material to furthest material. (It should be!)
3. Right clicking using material picker, then left clicking anywhere (NOT selecting a material from the drop down) resets render. (And often selecting a new material likewise resets render)
4. Right-clicking with material picker often fails to bring up material menu--takes multiple clicks to get drop-down menu to appear
Note: I do like the fact that you can now pick materials when the render is paused!
To problem 1): Are you using the multi-material picker (i.e. right mouse button)? There is one change I haven't mentioned yet: If the list contains only one entry, that material is selected immediately and no list is shown. This should save you one click.
To problem 2): As it was reported by several people, the next release will have the materials sorted by distance again.
To problem 3): The problem here is that the right mouse button is also used for camera panning and as far as I can see even slight moves during the mouse click cause the camera to change and restart the render. I have made now a change that introduces a small threshold if one of the picking tools is enabled. If that mouse movement is below that threshold, we don't change the camera. This change will be a available in the next release. As an alternative we could lock the viewport completely if one of the picking tools is enabled. Let me know what you think.
To problem 4): I think it's the same change as described in 1): If there is only one material, it gets selected immediately and no pop up list is shown.
Cheers,
Marcus
