Yeah, I am using Octane mostly in direct lighting mode, too.
This is a key strength of Octane.
Instancing will come soon. I really hope the gonna implement SSS, too.
The direct lighting has to be tuned a bit. Then it is all good.
semi transparent shadows in direct lighting - WHEN???
Can't say I'm against in any way, but don't remember using direct lighting for something else than navigating if fps drops really low. Isn't that kind of simulating "any other" rendering engine? Picture is always better with pathtacing. (no, I don't have a box full of GPUs
http://www.visnevskis.com
Vista64/Ubuntu, GTX470/580
It is all about options. If you can choose between a sweet rendering in seconds or a brillant rendering in hours what would you choose?
There is no definate answer because it is allways about the circumstances. Deadlines, late modelling changes and the aim to create an animation in hours, not years make DL attractive.
If I have time to render a single frame over night, of course PT or PMC is the better option but for everything else I go with DL.
If I would replace my 4 GTX 460 with 4 GTX 590 it wouldn't matter, but for now I enjoy Direct Lighting
mate are you earning your dollars with single frames only ? or you are lying about Gpu boxes!:)kivig wrote:Can't say I'm against in any way, but don't remember using direct lighting for something else than navigating if fps drops really low. Isn't that kind of simulating "any other" rendering engine? Picture is always better with pathtacing. (no, I don't have a box full of GPUs)
Another key feature DL could have is some colorbleeding a-la renderman... right now the colorless AO makes renders look kinda dull...
Win 7 64bits / Intel i5 750 @ 2.67Ghz / Geforce GTX 470 / 8GB Ram / 3DS Max 2012 64bits
http://proupinworks.blogspot.com/
Guess I didn't take all problems into account. I do animations, but I rarely do architecture. Pack-shots for instance are much faster in Octane than on CPU in most cases. I wish I had those boxes thoughtyrot wrote:mate are you earning your dollars with single frames only ? or you are lying about Gpu boxes!:)
