OctaneRender® 1.024 beta 2.48 TEST (win) [OBSOLETE]
Jaberwocky
Actually you'll soon have to pay for the card and then pay Nvidia the same again to buy a driver to be able to run it at all. :D
Populus
Portal test:
One portal covering each window.
All images rendered for 30min @ 2048*1024, then resized to 1024*512. After spending half the day on this scene I realized it was not a very good test for portals, doh! But at least some difference is showing; pt+portal has less noise than pt but loose a little saturation/contrast. pmc+portal has very clean walls but the specular floor has so much noise that the legs of the chairs almost disappear! Also even if very faint in these renders it looks like light/shadows get greater precision with portals. For now it looks like pt+portal is the winner in this kind of scenes, but I´m sure there are optimizations to come for the pmc kernel.
win 7 x64 / i7 920 / 12GB / gtx 470 + gtx 480
Jaberwocky
Small bug report
The attached screens says it all.I have reported this before.
Rename this node and save your scene at your peril.If anyone does this then the scene is a goner...dead, it's deceased....It is a dead scene.It's gone to the great renderer in the sky.
( said In the tone of Monty Pythons dead parrot sketch !!!!!)
This node really does need locking off before someone else has a go on purpose or by accident and then breaks down in tears shouting why oh why when they can't load it!
necko77
Render time 16:00 minutes
octane render 2.48 and 2.47
PMC 2.48, portal ON
PT 2.48, portal ON
PT 2.47
PMC 2.48 wins over PT 2.47
PMC 2.48 wins over PT 2.48
PT 2.47 wins over PT 2.48 ??? :)
When i introduce glass in interior, PMC engine shows why its better with coustics then others
Strange thing is that PT 2.47 have better image quality over PT 2.48 with portals !
ArchiCad, Blender, Moi3d
GTX 580 3GB
Win 7, 64 Bit
Refracty
from time to time I make the experience that there are dot patterns in the ambient occlusion (Direct Lighting Engine).
I could only attach small crops of the scene, because of non disclosure stuff.
But it is everywhere where AO shadows are.
The total scene is quite large. 1km * 1km but has only 800 MB. Maybe it is the dimension but the scale factor is right and it is working fine with 2.46b.
Any ideas?
necko77
BUG. 2.48
HDRI image is visible trough wall on PMC and PT
DL work fast...pllz make light pass trough glass in DL...its so fast...that could be great for everybody :) except you programers :)
PMC 2.48
PT 2.48
DL 2.48
DL 2.48 alphachannel enabled
GTX 580 3GB
Win 7, 64 Bit
Refracty
necko77 wrote:pllz make light pass trough glass in DL
+ 1000000
colorlabs
Hi, it seems that the Mix Material "Amount" slider has been reversed. I don't know if this is a new issue in 2.48 or not, but shouldn't increasing "amount" make material #2 show up more? Currently if I move it up to 1.00 it shows material #1.
Mac OS X 10.8.0 | ASUS GTX 580 1.5GB | MSI GTX 470 | ATI Radeon 6870 | Core i7 2.9Ghz | 16GB
dave62
necko77 wrote:BUG. 2.48
yep i experienced the same.
as long as alphashadows is enabled you can see through the walls whenn using hdri backround
btw big thanks to the team! portals :mrgreen:
- Mint 10 64bit nvidia drv 260.19.29/cudatoolkit3.0 intel q6600, 4gbRAM, GTX470 1,2GB
- Mint 10 64bit/ Win7 64bit nvidia drv 260.19.29/cudatoolkit3.2 amd X6, 16gbRAM, 2x GTX580 3GB
->Octane 2.44/ Blender2.5x
pixelrush
do you want us to keep testing this or should we wait for test 'b'? :roll:
i7-3820 @4.3Ghz | 24gb | Win7pro-64
GTS 250 display + 2 x GTX 780 cuda| driver 331.65
Octane v1.55
