GTX 590 issues
GeoPappas
ribrahomedesign wrote: IMO it should show 2 cards ????
I would think that it would only show 1 card.
ribrahomedesign
so that means that the card is instaled properly ,why is octane not showing two cards ?
Windows 7 , 64 b / GTX 590 / Archicad 15 , 64 b / Cinema 4D R 13 studio , 64b /Intel(R)Core(TM)Extreme3,20Ghz /always latest Octane.
i think you must disable physics for both gpu in order to use all in octane :roll:
ciao beppe
ribrahomedesign
Physics is off. i will try now to install the card on my second workstation and see what happend ,
Rico
ribrahomedesign
ok it works on my 2. machine.
its time to dump one of my machines.
thanks to everybody who tried to help me .
Rico
Please Rico, can you post the screenshot of the nvidia contropanel of the new machine?
my gtx 590 is just arrived and I'm in your previous condition, only 512 cores are seen :(
ciao beppe
ribrahomedesign
Hi beppe
i still dont know what the problem was with my older machine.
Timmaigh
ribrahomedesign wrote:Hi beppe
This is how it was supposed to look like. I wonder about same thing, the issue with your other machine...perhaps lack of SLI capability of the mobo?
Intel Core i7 980x @ 3,78GHz - Gigabyte X58A UD7 rev 1.0 - 24GB DDR3 RAM - Gainward GTX590 3GB @ 700/1400/3900 Mhz- 2x Intel X25-M G2 80GB SSD - WD Caviar Black 2TB - WD Caviar Green 2TB - Fractal Design Define R2 - Win7 64bit - Octane 2.57
thanks ribrahomedesign and Timmaigh, my mobo is not good enough, it seem that i will work with 580 instead of 590 for some time :(
i've found this, but i don't know if is the solution :roll:
http://xdevs.com/e107_plugins/content/c ... content.30
ciao beppe
ok, after an afternoon spent in putting on and off all my cards, i've found the solution.
The SLI in not a problem, my motherboard is only crossfire, the problem was the GS8400 in the PCI slot that failed the nvidia driver installation. I've put it in a drawer, attach the monitor to one 590 and now I have 2x GTX 590 with 4 GPU for octane, not bad ;)
it's time to update my signature
ciao beppe
