some test
yplanet
any comments?
i5-2500 CPU @ 3.30GHz, 8GB Ram, EVGA GTX 460 1GB, Windows 7 64bit
Bulwerk
I have some feedback for you. First impression for me is, it seems flat in terms of light dynamics. Too evenly lit. It would be nice to have some beautiful light casting in through the opening where the stairs come down and through some windows. Another aspect is the low poly look seen in the bends of the spiral and the rounded corners of the walls. the best aspects of a unbiased engine is its ability to splash light around in a realistic way. So cheers on the project just needs some more work to make it more than just a test render.
This is a good reference rendered with Indigo
http://www.blender.org/index.php?eID=tx ... 0b1eaa7a22
yplanet
thanks for your reply, it's really a big help.
thanks for pointing out for the flat lighting, actually i didn't use daylight for the first render. I still trying to figure out how to make some light casting through the opening where the stair come down.
As for the low poly, i guess i will need to redo to higher details when i have time. ;)
sam75
the over exposed areas are weird
Win7 x64 - I7 920@4Ghz - 6Go DDR3 - GTX470
Return to “Works In Progress”
