I have a question:
it is normal that the sunlight does not pass through glass?
I add a picture showing how the sun does not creates shadows-lights inside the building...
I use pathtracing kernel...
Thank's
Glass properties
- mib2berlin
Yes, at moment only hdr or meshlights.
You could fake it with a glossy material, rougness to zero, specular up and opacity to 0.5.
Cheers, mib.
Cheers, mib.
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
hi mib
I try to do what you say but the result is bad
1) whit hdri ther's not sun into my object, there's not shadows in all render!
2) whit glossy material the glass is not clear but is white
Where i wrong if i wrong??
Is a big problem for exterior renders!!
SORRY, MY ENGLISH IS BAD!
2 Xeon quad core E5440_8gb Ram_Nvidia GeForce 2GTX 780ti 3Gb/Nvidia Quadro K2000_Win10 64bit_Octane 3.02_Rhinoceros3D
This is a weak point of the kernel.
I had the same problem:
http://www.refractivesoftware.com/forum ... =33&t=6199
I am not using the "flipped normal trick" with the glossy. I simply use the specular but decrease the oppacity to 0.1 or 0.2.
The new version 2.5 with the kernel will probably solve this issue.
