Sketchup Animation - Automation Error
arkeyt3kt
Whenever I have tried to export an animation from SketchUp, I get an automation error. The first on tells me that the the "mesh file for import could not be found". It shows the file name that I designated in the dialog box, but when I look in the folder I see the file name, with "_anim.obj" added to the end of it. It seems like the exporter is creating one file name, and the octane cmd script is looking for a different one.
I was able to edit the cmd script file to change the name of the *.obj file to add the "_anim.obj" and it seems to work fine. I think that one of the ruby scripts needs a little tweaking.
TIG
What's your OS ?
Can you post a screenshot of the files that do get made ?
I can get a proper sequence of animated frames to be made and render with anim_cmd files :?
TIG
pimpuppy
hi Tig! and thanks for helping us using octane render :)
i'm having the same problem with automation error.
i have tried a small test animation and i stumbled on first step ...
attached are screenshots of cmd file , folder location, skp window and error message.
i'm doing something wrong? :roll:
thanks!
Hardware : AMD Ryzen5 5500 - 3.6GHz / DDR4 40GB / GTX 1080TI
Software : win 10x64 / Octane Render Version 4.05 / SketchUp 2018x64
TIG
pimpuppy
You must have initially run a Render [one frame] on the project to make the base OCS [and OBJ file for that etc] - in your case '1.ocs' and 'i.obj' etc. The animation needs these for its other settings. It then makes '1_anim.obj' to use temporarily during the animation - it is auto-deleted on completion - unlike the base '1.obj' file used for the main Render's mesh which must always be kept/updated...
Please retry and report back...
TIG
pimpuppy
ok. now i understand. i'll give it a try tomorrow.
thanks and best regards!
pimpuppy
all is good now.
tested and works fine.
many thanks!!! :)
TIG
Hooray!
I like a happy ending :D
TIG
Return to “SketchUp”
