tiny tiny objects or far cam?
illmonkey
Hi!
When i export from max to octane my object are at first not visible, i have to zoom in in order to see them. I have looked around the forum and did the following:
1. my working units are Metric->Meters
2. "obj export options" are set according to http://www.refractivesoftware.com/forum ... f=21&t=362 (can i get to this optionbox without at first manually exporting a OBJ?)
3. i've checked the focal depth and roll (ive tried with and without)
3dsmax 2011
Max2Octane 1.022g
Octane beta 2.4
thnx
/F
Windows 8 | i7 930 | 20GB Ram | 2x580 GTX 1500MB | Octane 1.1
illmonkey
hmm i notice that the scale is at 0.025 when i click "Export OBJ/MTL only". I change this to 1.0 and click export and after that i click "render" and it exports again.
Still tiny tiny, but i notice that when i choose "Export OBJ/MTL only" the scale is still at 0.025.
After changing "System Unit Setup" to meeters aswell I am getting 1.0 scale in the export but still the objects are so small i have to zoom in to see them in octane. Bit strange, I've searched around the forum and I seem to be the only one with this problem scaresly enough. :D
The tiny tiny darker spot in the middle is my objects
illmonkey
anyone?
kilaD
Is it too small when you dont change the settings? when you leave it at 0.025?
Anyway try this version, it has the auto-rescale off. The regular version rescales the scene when you press render
max2octane_1.022g_rescaleOff.rar
rescale off
(6.58 KiB) Downloaded 353 times
Hello
illmonkey
Thank you so mush!
Return to “Autodesk 3Ds Max”
