can't see my geometry
Forums: can't see my geometry
Postby manos » Thu Jan 27, 2011 9:36 am
manos Thu Jan 27, 2011 9:36 am
Hello, just donwloaded the latest exporter 1022-14 and the latest octane 2.42.
I sometimes see my geometry and some other times i can't.
Eny ideas ?
THANKS
CPU: INTEL i7 3.40 GHz/RAM: 8 GB/GPU: 2XGTX690/OS: WIN 7 64 BIT/SKETCHUP 2014/OCTANE for SU
manos
Re: can't see my geometry
Postby TIG » Thu Jan 27, 2011 10:33 am
TIG Thu Jan 27, 2011 10:33 am
The clue might be in the names... 1022 exporter works with 2.2 and although the 2.3 version is 'in progress' 1022 should usually work OK with a new OCS made in that newer version too. But it's untried on 2.4...
Are you staring with a fresh 2.4 based OCS? Is your geometry near the SKP origin? Are you exporting the camera ? etc - We need a few more clues from you too.... :?
TIG
TIG
Postby manos » Thu Jan 27, 2011 11:06 am
manos Thu Jan 27, 2011 11:06 am
I tryed also the 1022-12 vertion, exporting the camera or not i have no geometry on octane. ?????
This is what i get.
manos
Postby TIG » Thu Jan 27, 2011 2:38 pm
TIG Thu Jan 27, 2011 2:38 pm
Use the latest version of the exporter.
If you do not export anything all you get in the export is the OBJ/MTL/Textures.
The OCS opens using the default camera placed/looking at the origin, also there is basic lighting set.
Try exporting it again with export-camera [say 50% resolution for speed] and export-lighting both checked.
See what happens...
After you have the view/lighting as wanted in the OCS you can uncheck those options and export just the current geometry and new materials...
TIG
TIG
Return to SketchUp
Mon Oct 26, 2020 10:03 pm [ UTC ]
