Non-offical Blender 2.56 plugin
- SamCameron
Thanks for the info face, now I have problems with materials, I had an object with two textures, a diffuse one, and a bump map, I deleted the bump map, and rendered with Octane (with overwrite project checked) and Octane shows two materials, instead of one, so doesn't update the deletition from blender, I don't know what happens, the script is getting mad with the materials updates.
Blender's normal maps are used as bump maps into Octane. The script doesn't go crazy with materials, check the generated mtl file and the command line options before claiming something is wrong.
The following is untouched output directly from blender (except pathtracing), with a diffuse texture and a bump map.
Desktop: Ubuntu 13.04 x64 - i7-3770K @ 3.5GHz - 32GB DDR3 - GTX670 2048MB
Laptop: Linux Mint 11 x64 - i7-2860QM @ 2.5GHz - 16GB DDR3 - Quadro 3000M 2GB
Software: NVidia 319.12 - Cuda 4.2.9 - Blender 2.66a
yoyoz, i need the blender hair rendered in octane for the competition.
Is it possible?
Bytheway very nice script so far!
Is it possible?
Q6600 || 4GB || 9800GT || 512MB || Vista Home || C4D 9.6 & Blender
tungee, Octane cannot render strands so you need a base mesh on which you apply a particle instance refering to your particle system. Finding the appropriate shape is quite tricky, but it works. On page 2 of this thread you'll find a render I made using this method, and another one from Steve on page 4.
yoyoz, do you have a blend file for this?
Yes, here's the one I used for my example.
- grass.blend.zip
- (683.72 KiB) Downloaded 269 times
Thanx yoyoz!
thank you for your effort yoyoz.
soon - possibly next week - we have an exporter that does more than Octane does
perhaps then we get you unofficially on the Octane team doing all the little usability improvements people have been asking for...
i7-3820 @4.3Ghz | 24gb | Win7pro-64
GTS 250 display + 2 x GTX 780 cuda| driver 331.65
Octane v1.55
Octane v1.55
Thanks guys, I'm pleased you appreciate the plugin.
*** Important notice ***
Due to another API change the plugin will crash with builds 34610 and higher. You better not upgrade blender at the moment as I've no time to find a fix at the moment.
