anybody succeed to recreate this in max ?
HHbomb
anybody succeed to recreate the foam material in max ? I don't even know how to create the volume at the beginning ! :lol: :lol: :lol:
https://www.youtube.com/watch?v=sdms7YdYh4Q ( Silverwing rocks )
thanks
remKa
Hello,
Yes someone did it here : https://www.facebook.com/groups/stackth ... 033540548/
But there is still something missing that prevent the texture to follow the volume when it moves.
Octane devs should look into it :)
AMD 9950x3D / RTX 4090 / RTX 3090 / 192 Go DDR5 / Win 11
http://www.remy-kerbiquet.com
coilbook
Does anyone have a sample 3ds max file? Thank you
paride4331
HHbomb wrote:Hi,
thanks
Hi HHbomb,
viewtopic.php?f=27&t=81392&p=422758&hil ... me#p422758
paride4331
remKa wrote:Hello,
Hi remka,
That should be resolved by using world space instead of object space. Have you tried it?
HHbomb
Hi, Thanks Paride !
I was searching in Octane Geometry properties > Mesh to volume SDF...
Now I have a volume ( need to have Quick update mode to render )
How can I connect noise to density ?
paride4331
I'm attempting to determine if freezing the textures resolves the issue, but I'm uncertain.
I did it quickly, it will need to be properly adjusted, but the material is there.
01f.zip
(1.89 MiB) Downloaded 125 times
HHbomb
Hi Paride !
You are sooo kind to take time to help !
I was trying to use "volume medium" and not "std volume medium".... :roll:
and nothing was corresponding ( obviously )
why I didn't see "Std volume medium" is something I'll discuss with my ophthalmologist.
Thank you very much !
Next is the sliding texture :D
remKa
Thank you Paride !
coilbook
paride4331 wrote: Thu Apr 04, 2024 2:15 pm Hi,
Hi Paride,
Do you know why new octane renders foam so clear? And is there anyway to use this with phoenix fd foam as one single mesh having all foam properties?
Thank you
Return to “Autodesk 3Ds Max”
