OctaneRender® 2026.3 for 3ds max® v26.9
neonZorglub
3ds Max version supported: 2013 to 2027.
Important notes:
The minimum NVIDIA driver version required has been raised to R528 (R572 for GeForce RTX50 Series).
The GPU version of Open Image Denoise is supported on Volta and Ada GPUs currently. The CPU version is used on devices with other models, and on macOS.
What's new in 2026.3:
OctaneRender® 2026.3 : viewtopic.php?t=85624
OctaneRender® 2026.2 : viewtopic.php?t=85487
OctaneRender® 2026.1 : viewtopic.php?t=85315
Changes of the 26.9 version, from 26.8
  • Fixed crash with large volumes generated by tyFlow
  • Fixed memory leak when rendering tyFlow volumes
  • Updated GPU out of memory error handling.
  • Fixed viewport issues with Octane Volume when changing load Units
  • Fixed orbx export for volumes generated by tyFlow, PhoenixFD
  • Added option to keep generated VDBs after orbx export [Tools / Export settings section]
  • Added tyFlow VDBs export options [Tools / Octane export section]. See details here: viewtopic.php?p=443732#p443732
Previous versions changelog:
Changes of the 26.8 version
- Updated to Octane 2026.3
- Added support for tyFlow Volumes / Inferno - Tutorial and samples to be posted shortly
- Fixed issues with Volume point cloud display in 3dsMax viewport
- Updated some node's parameters to use a Percentage display
- Fixed incorrect camera Motion blur default settings (shutter time, sub frame end)
- Updated VDB support to allow color channels
- Fixed issues with lights, target distance, UI
- Fixed incomplete conversion of Corona Physical material
- Updated other Corona conversion and added option to change default roughness
- Added options in all textures dialog to Export to localDB as orbx and maxscript
- Fixed UI issue with Octane lights size showing 0 when loading old scene
- Fixed issue with Trace Set when using instances in several Octane modifiers
- Added maxscript function OctaneMaxFPI.OCMSetUniqueNames to rename textures of materials if not unique.
Changes of the 26.7 version
- Added support for 3dsMax 2027
- Fixed issues with ImageTile and ImageTileSet textures (copy operations, Grid mode, Undo/Redo, ui)
- Fixed issues with Cameras and Lights
- Updated Cameras UI
- Fixed viewport bug with render region + compare tool
Changes of the 26.6 version
- Fixed issue with Motion blur settings in camera objects
- Fixed issue with editing Spread start and end in camera Post Processing
- Added missing parameters when copying camera parameters with Camera Tools
- Fixed minor memory leak
- Fixed issue with VDB filenames and digit count (incorrectly expecting leading 0s, eg xx_001.vdb)
- Fixed issues with Vectron operators, failing to use other operators as input
- Fixed issues with Vectron geometry inputs, not supporting geometry Pivot point.
- Added input nodes display in 3dsMax viewport for all Vectron operators
Changes of the 26.5 version
- Updated to Octane 2026.2
- Fixed crash with some textures
- Added missing Image Tile Set texture
- Fixed issue with tyFlow particle ID - added 'Birth Base ID'
- Fixed issue with imager upsampler
- Fixed issue with materialX sub parameter expansion
- Fixed issues with VRay material
- Fixed issues with PhoenixFD VDB volumes
- Added textures and material descriptions in UI when available
Changes of the 26.04 version
- Fixed conversion issue with material's new IOR
- Added new Reciprocal wrapper texture for IOR conversion
- Updated PhoenixFD liquid modifier to remove channel scale limits of 1.0
Changes of the 26.03 version
- Updated to Octane 2026.1
- Updated Virtual textures cache settings (Preferences/Material)
- Updated Meshlet cache settings (Preferences/Material)
- Added spz export functions (Context menu in Gaussian Splat filename)
- Added Octane new material (Open PBR Surf. Mtl)
- Added support of Autodesk 2026 PBR materials
- Updated Octane Geometry modifier to support 10 color and 10 float attributes
- Fixed issues with File sequences digit count (VDBs, images, ...)
- Fixed UI issues with some 2 floats parameters (eg OctaneLight's Size X,Y)
- Fixed issue with motion blur when object is attached to camera.
- Fixed issues with MaxScript.
Changes of the 26.02 version
- Fixed 3dsMax 2025 and 2026 occasional freeze - see details here: https://render.otoy.com/forum/viewtopic.php?p=441102#p441102
- Updated support of Autodesk USD plugin to current version (12.0)
- Added support for Forest pack IVY - Samples and tutorials : https://render.otoy.com/forum/viewtopic.php?t=85145
- Added support for Autodesk Double Sided material
- Added support for Autodesk Composite material
- Added support for Material editor preview of multi-Material with non Octane materials
- Added support for opacity maps when converting from Autodesk Physical materials
- Added support for velocity for Phoenix Fire Modifier.
- Fixed issues with Value textures for OSL textures
- Fixed minor issue when saving scene as older max version
Changes of the 26.01 version
- Updated to Octane 2026.1 Alpha3
- Added Gaussian splat support. See tutorial and samples here: [link coming shortly]
- Added Meshlet support. See tutorial and samples here: [link coming shortly]
- Added Virtual textures support. See tutorial and samples here: [link coming shortly]
- Added native MaterialX support. See tutorial and samples here: [link coming shortly]
- Added Trace Set support (visibility rules). See tutorial and samples here: [link coming shortly]
- Fixed issues with Octane Volume objects
- Fixed issues with Gradient textures
- Fixed issues and crashes with Puzzle Scene manager / Renderflow plugins
Changes of the 16.06 version
- Updated to Octane 2025.2
- Added support for 3dsMax 2026
- Fixed several issues with VRay light conversion
- Added option to use the Texture in Octane light when using Temperature mode.
Changes of the 16.05 version
- Fixed fov bug with Realistic camera
- Fixed issues with Realistic camera
- Fixed issues with TexRandomizer
- Fixed compatibility mode issue when loading old scene with textures without projection
- Fixed UI display update with animated object's visibility.
- Fixed empty Render settings dialog still occurring in one case.
- Fixed crash with AB comparator
- Updated Asset Explorer, with asset list sorting by column,  ++++https://render.otoy.com/forum/viewtopic.php?f=27&t=84035
Changes of the 16.04 version
- Updated to Octane 2025.1 Stable
- Added driver version information in the Render settings / Devices tab
- Added TexRandomizer texture, to set random textures per mesh element. Samples and tutorials will be available shortly.
Changes of the 16.03 version
- Fixed Orbx export issues: incorrect start frame and frame count
- Fixed Multi-texture wrapper, Seed and Power incorrectly updated.
- Added options to clamp, offset and scale cell values of Phoenix FD fire volumes
- Fixed issue with Ornatrix hair animation timing
- Updated Octane proxy object
- Fixed Render settings empty rollout issue
- Fixed OSL parameter type issues
- Fixed OSL update issues
Changes of the 16.02 version
- Updated to Octane 2025.1 Beta 2
- Updated camera dialog to update target distance correctly
- Updated Decal object to display wireframe using the assigned material / color
- Fixed issue with normal map / bump map inverted when converting material from a Standard (Legacy) material.
- Updated OMGuardian dialog for the 3dsMax 2025 freeze issue. See updated post there https://render.otoy.com/forum/viewtopic.php?f=81&t=83983&p=438075#p438075
Changes of the 16.01 version
- Updated to Octane 2025.1 Beta 1
- Added support for Rest attributes. See samples : https://render.otoy.com/forum/viewtopic.php?f=27&t=84535
- Added Vectron displacement : See samples:  https://render.otoy.com/forum/viewtopic.php?f=27&t=84536
- Added new 'Spectral LensFX' Camera ('Realistic Camera')
- Added new Decal system. See samples:  https://render.otoy.com/forum/viewtopic.php?f=27&t=84537
- Updated Chaos Texture
- Added 11 new blend modes for output AOV layers
Changes of the 15.12 version
- Fixed Crash when copying IES texture and Material Selector
- Fixed Issues when cancelling creation of some Octane objects
Changes of the 15.11 version
- Updated to Octane 2024.1.2
- Fixed Compatibility mode issues
- Reduced occurrences of 3dsMax 2025 freezing issue
Changes of the 15.10 version
- Fixed crash when editing Octane cameras, and other Octane objects
Changes of the 15.09 version
- Fixed issue with layered material not accepting drag and drop of base material
- Fixed issue with Composite texture when created from Slate editor
- Fixed issues with several textures when created from Slate editor
- Reduced occurrences of 3dsMax 2025 freeze
- Added a custom dialog 'OM Guardian' to unfreeze max 2025 - details to be posted shortly
Changes of the 15.08 version
- Added support for rendering PhoenixFD fire as mesh (Octane geo modifier / Phoenix object) - See sample here: https://render.otoy.com/forum/viewtopic.php?f=27&t=83730&start=10#p435364
- Added scene loading Performance report in Preferences / Trouble shooting
- Added option to disable viewport display in Octane Volume
- Added an Asset Explorer, for investigating scene issues and fixing missing textures and other assets - see https://render.otoy.com/forum/viewtopic.php?f=27&t=84035
- Added new pick AOV White balance
- Updated deep image exr export.
- Updated Gradient Texture dialog - see https://render.otoy.com/forum/viewtopic.php?f=27&t=83901#p435349
- Updated all Texture creation to add default Transform and UVW sub textures.
- Fixed multiple issues with Material DB import
- Fixed issues with Scatter volume, Scatter surface
- Fixed issues with Export passes to Render Elements
- Fixed issues with AOV mode, legacy mode
- Fixed issues with instances visibility animation
- Fixed issues with AOV support
- Fixed issues with instance animation with some render options
- Updated Directional lights: can now be used as multiple instances
- Updated Octane Texture thumbnails for Map Browser (Use Additional Options/Clear Preview Thumbnail Cache once to update)
- Added auto viewport closure system for freeze happening with 3dsMax 2025 - See Preferences / Trouble Shooting - https://render.otoy.com/forum/viewtopic.php?f=81&t=83983#p435345
- The Octane viewport shows an animated 'heart beat' icon in the title bar - See Preferences / Trouble Shooting[/list]
Changes of the 15.07 version
- Updated to Octane 2024.1 Alpha 4
- Updated Orbx proxy to support animations, and Orbx Reference options
- Added orbx export options to export as Orbx Reference, with animated bounding boxes
Changes of the 15.06 version
- Added support for 3dsMax 2025
- Added support of Compare AB button access via OctaneMaxFPI.ViewportSetControlState 16
Changes of the 15.05 version
- Added Image Comparison tool in Octane Viewport - more information will be posted shortly
- Added scriptable AOV outputs presets - - more information will be posted shortly
- Fixed issues with PMC and Info channel UI
- Fixed issues with Composite texture layer group
- Fixed crash with Environment texture in Material editor when dragging the timeline
- Fixed crash when rendering with 'Skip Existing Images' and all images already rendered.
Changes of the 15.04 version
- Updated tyFlow support for tyCache, and access to custom data to use as Octane instance ID - see tutorial and samples here: https://render.otoy.com/forum/viewtopic.php?f=27&t=83181
- Added 'Conceal Layer' option in materials to partially and temporarily disable sub materials (layer) (for Ornatrix display work around). see post here https://render.otoy.com/forum/viewtopic.php?f=27&t=83180
- Fixed issues with Environment light dialog when droping texture and medium to the buttons.
Changes of the 15.03 version
- Updated to Octane 2024.1 Alpha 3
- Added support for Phoenix FD fire color - tutorial and samples to be posted shortly
- Updated tooltips and context menu of the Octane Viewport 'Save Image(s)' button
- Fixed issue with image pitch
- Fixed missing update of enabled AOVs in Aov Scene Settings dialog when changing a Render AOV layer.
- Fixed UI issues with Compatibility mode when multiple rollouts are enabled
- Fixed Std Surface material missing the Medium group
- Fixed Forest pack issue with Pivot and Direct mode
- Fixed issues with Tile texture UI
- Added a divider to material's Rounded Edges radius
- Updated Switch nodes, and the Value textures to control input from a common texture
Changes of the 15.02 version
- Updated to Octane 2024.1 Alpha 2
- Fixed missing IES texture
- Fixed UI issues in material editor
- Updated light mixer tool to create new light mixer AOV layer
Changes of the 15.01 version
- Updated to Octane 2024.1 Alpha 1
Changes of the 14.06 version
- Updated to Octane 2023.1.1
- Fixed issues with Volume Ramp UI
- Added missing 'Max value' to Volume Ramp.
- Fixed issues with Post processing with normal Render
- Fixed incorrect layer number displayed in layer names
- Fixed 'Use volume step lenght for Volume shadow' checkbox not updating shadow Ray edit box
- Added Value textures for all float, int and boolean parameters of textures and materials. [still experimental, to activate in Preferences / Trouble Shooting], samples and tutorial coming shortly.
-Changes of the 14.05 version
- Fixed Cutoff value of Kernel Camera not updating in the viewport
- Fixed Spread limits of camera's postprocessing not consistently set correctly
- Fixed UI issues with Analytic Light with mode 'Expand Object Dialogs width'
- Fixed UI issue with layered textures not showing the layer drag button with some Desktop scale values
- Improved AOV Light mixer UI.
- Set the DPI to all Octane windows (live DB, network preferences, device settings, graph viewer,..) to match Windows Desktop scale used by 3dsMax
Changes of the 14.04 version
- Fixed Analytic Light's Object layer settings (Camera visibility, etc)
- Fixed case where orbx export was using incorrect motion Blur settings.
- Fixed export of Directional light
- Fixed animation cache for Directional light and Analytic light
- Fixed issues with 3dsMax startup, not fully loading the plugin (Preferences / Troubleshooting / Plugin Dereferred Load)
- Fixed issue with Octane as default renderer not working (Preferences / Troubleshooting / Force Octane as Startup Renderer)
- Fixed Light pass ID 9/10 incorrect values from Octane Object Properties
- Fixed Camera conversion issue from Camera Lister
- Fixed crashes with Physical Camera when using Animation cache
- Added Maxscript reference text document generator (Preferences / Info menu)
Changes of the 14.03 version
- Fixed gradient texture UI
- Fixed volume gradient Reset
- Fixed composite texture layer group layer order
- Fixed 'Any Plugin Texmap' mode (Preferences/Material) allowing selection of incorrect Octane texture type
Changes of the 14.02 version
- Updated to Octane 2023.1 (stable)
- Added missing material conversion for 3dsMax material libraries - Use Preferences/Prev. Versions to specify old libraries version if needed.
- Added MaxScript functions to control render passes
- Added color multiplier in custom light mixer
- Added support for animated colors and values in TexSelector's Texmaps
- Fixed issues with Layers, and re-ordered pins to match Slate editor view
- Fixed issues with Gradient textures  (assignment of texmap as gradient color, incorrect UI update)
- Fixed issues with Texture Selector
- Fixed issues with default Bump height value
- Fixed issues with Cameras OCIO settings
- Updated Hue shift values support to match reverted range to (-1 / +1)
Changes of the 14.01 version
- Updated to Octane 2023.1 Beta 3
- Updated to the new AOV system, using Texmaps
- Added new Analytic and Directional lights
- Added light passes 9 to 20.
- Added new Composite Texture (named Composite Texture Ex)
- Added Post Processing effects as a Texmap
- Other updates to textures, materials and other nodes, as described in the 2023.1 posts.
- Improved support of old 3dsMax plugin scenes
- Added maxscript commands to get and set parameters by name and ID - see updated maxscript post: https://render.otoy.com/forum/viewtopic.php?f=27&t=62173
Changes of the 13.21 version
- Fixed Octane light sphere size when using Vectron
- Added  'Visible on scattering volume', and 'Transparent emission' to Octane Light and IES light
Changes of the 13.20 version
- Fixed Fov update missing for Octane camera in Ortho mode
- Added safer detection of TyFlow and Ornatrix version, to avoid MaxScript errors causing BackBurner to fail.
- Added TyFlow and Ornatrix version options in Octane Preferences
- Added Ornatrix baked hair abc support
- Added support for lens shift for VRay camera and standard physical camera
- Updated camera conversion with lens shift support
Changes of the 13.19 version
- Added Camera lister dialog with conversion to Octane cameras. (Render Settings / Camera / Camera Tools)
- Updated OCIO issue fixer dialog
- Changed object's Layer Id range to [1,255] instead of [0,100]. Invalid previous ID values of 0 will be set to 1
- Fixed crashes when loading a new scene, after rendered a previous scene with AOV output enabled
- Fixed orbx exporter issues when ABC mode is enabled.
- Updated Animation cache support (Experimental - details to be posted soon)
- Added Animation cache fixer dialog, to help convert incompatible items and setting optimal performance.
Changes of the 13.18 version
- Added support for 3dsMax 2024
- Updated to Octane 2021.1.1
- Fixed Octane Volume transform animation not updated in viewport when using instances.
- Fixed unnecessary need to enable Movable proxy for MeshVolume
- Fixed incorrect UI for MeshVolume after resizing object's dialog
- Fixed Instance color texture not loading image data
- Fixed double saving of cryptomatte EXR passes.
- Added option to set the number of digits used to save custom animated output files (exr).
- Added option in Preferences to enable the use of 'Oct' suffix added to output images.
- Added an OCIO issue fixer dialog, to help rendering scenes with invalid OCIO settings.
- Added experimental animation cache for Octane viewport (details to be posted soon)
Changes of the 13.17 version
- Fixed exr saving for animated sequences with Octane EXR instead of 3dsMax EXR.
- Fixed Universal camera parameters not updated.
- Fixed occasional crash when loading older version
- Added TextureSelector texture to assign textures based on material ID. See samples and tutorial here.
- Added MeshVolume object to create volumes or SDF volumes from scene objects. See samples and tutorial here.
Changes of the 13.16 version
- Fixed Forest pack View Clipping not updated is some cases.
- Fixed VDB animated position not updated in Octane Viewport
- Fixed FOV not updated when changing max viewport with motion blur enabled, from an ortho to perspective view.
- Fixed incorrect light orientation when scattered by Forest pack with Vectron mode enabled.
- Fixed Additional Zoom Key preference not saved.
- Fixed singled image output files not saved when option multi exr was used
- Fixed issues when saving exr or using output folder overwrite while render element file types are not exr.
- Added option to save single exr passes as Octane exr instead of 3dsMax exr.
- Added a Material Index generator in Octane Geometry Modifier, to be used by Material Selector. See updated Material Selector post here: https://render.otoy.com/forum/viewtopic.php?f=27&t=80663#p422120
- Added options to change Octane material types (eg from Glossy to Toon). See tutorial here https://render.otoy.com/forum/viewtopic.php?f=27&t=81261#p422117
- Added Material copy / paste options to copy compatible parameters to different materials, and to copy materials between multiple 3dsMax instances. See tutorial here: https://render.otoy.com/forum/viewtopic.php?f=27&t=81261#p422118
Changes of the 13.15 version
- Fixed crash when loading some scenes, showing MaxScript Call stack overflow error
- Fixed UI issues when switching renderer, showing empty dialog in some cases
Changes of the 13.14 version
- Fixed OSL texture parameter not updated when was set as Color
- Fixed several issues with materials
- Added support of Forest Material and Forest Color - see Tutorial and samples here https://render.otoy.com/forum/viewtopic.php?f=27&t=81068
Changes of the 13.13 version
- Fixed crash with Render elements using AOV outputs
- Fixed Octane Volume unnecessary updates when changing the node transform
- Updated Octane Volume channel selection to discard incompatible types.
- Fixed issues with orbx export for Octane geometry primitives and Phoenix wetmap
- Fixed issue with Ray epsilon new UI multiplier not used in Preferences
Changes of the 13.12 version
- Updated to Octane Render 2022.1 (Stable)
- Fixed issues with imager updates when changing 3dsMax viewport while Locked updates, Paused Render, Locked Camera.
Changes of the 13.11 version
- Updated to Octane Render 2022.1 RC3
- Fixed issue with cameras when 3dsmax viewport is maximized
- Fixed issue with Material Selector, not creating osl files with an unsaved scene (Untitled).
Changes of the 13.10 version
- Updated to Octane Render 2022.1 RC2
- Fixed crash with very big render size ( eg > 50000 x 50000)
Changes of the 13.09 version
- Updated to Octane Render 2022.1 RC1
- Fixed issue when using multiple IFL files, causing 3dsMax to fail reading files after several thousand renders.
- Fixed export failing when previous orbx file is manualy renamed.
- Added additional keyboard shortcut for zoom in Octane viewport (eg, for Wacom tablet, see Preferences/ Viewport: Ctrl + mouse buttons by default)
- Added Material selector material to select one material from a Multi-Material, by index, randomly or with custom a texture. See samples here https://render.otoy.com/forum/viewtopic.php?f=27&t=80663
Changes of the 13.08 version
- Updated to Octane Render 2022.1 XB4
- Added new textures and effects of XB4
- Added Compatibility mode parameter in relevant nodes (Kernel, Daylight, some textures, AOV layers, ...)
- Added Preference option to set Compatibility mode when loading old scene ('Prev. Versions' tab)
Changes of the 13.07 version
- Added a 'locked' backup preference file in Preferences / Preset menu - see Updated post on Preset. https://render.otoy.com/forum/viewtopic.php?f=27&t=76178&p=416236#p416236
- Fixed Octane Preset overwriting current preferences when disabling a Preset .
- Added 'Copy...' button in Octane Preset to copy to/from Preferences.
- Added MAXScript functions to backup and restore Octane preference file. See MAXScript post update: https://render.otoy.com/forum/viewtopic.php?f=27&t=62173&p=416230#p416230
- Changed Ray epsilon editable values - Valid values in the range (0.01,1000) are internally converted to octane range (0.000001,0.1)
- Removed incorrect change of spinner precision to 7 digits (as it affect all spinners)
- Added VDB save location options (Render settings / Kernel / Support, and Preferences / Kernel default) See VDB post update https://render.otoy.com/forum/viewtopic.php?f=27&t=80560
- Fixed VDB Preview file caching incorrectly still saving files when set to 'disabled'
- Improved VDB preview caching cancelation with ESC key.
- Added MAXScript call on Octane Viewport pre/post open/close (Preferences / Viewport). See MAXScript post update: https://render.otoy.com/forum/viewtopic.php?f=27&t=62173&p=416230#p416230
- Added missing support of FloatImage textures as input of Triplanar texture
Changes of the 13.06 version
- Fixed issues with tyFlow support, incorrectly rendering particles with no mesh operator
- Fixed issue with tyFlow support causing crash using IVI
- Fixed issues with Volume VDB preview and improved display cache system.
- Fixed custom AOV and global AOV passes not using parameters in normal render
Changes of the 13.05 version
- Updated to Octane Render 2022.1 XB3
- Added option to export animation with sub-frames (motion blur steps)
- Improved UI of some floating point parameters (eg Ray Epsilon) to view full precision numbers (see note bellow)
- Added Ray Epsilon default value in Octane Preferences / Kernel default. (Used when creating a new scene)
Changes of the 13.04 version
- Updated to Octane Render 2022.1 XB2
- Added new XB2 textures
- Added AOV Cryptomatte mask and picker [url=https://render.otoy.com/forum/viewtopic.php?f=27&t=80189]see here.[/url]
- Fixed issues with AOV export, AOV UI
- Added support for 3dsMax Photometric lights - [url=https://render.otoy.com/forum/viewtopic.php?f=27&t=80188]doc and samples here.[/url]
- Updated Vray IES Light support
- Updated Octane Light shape
- Fixed Octane IES Light additional rotation UI
- Added option 'Single texture' in Triplanar map to specify all 6 textures at once.
- Added Color value display when using White balance picker. [url=https://render.otoy.com/forum/viewtopic.php?f=27&t=80190]see here.[/url]
- Added option 'Force Linear' in imager, to help saving as un-clamped 3dsmax EXR
- Fixed Vray blend material multiplier.
- Added support for Undo in all render setting dialogs.
- Fixed support for Forest pack Version 6 and bellow
- Added options to save render passes in separate folders
Changes of the 13.03 version
- Fixed UI scalling issues (aka 4K monitor)
- Fixed Railclone issue with RC version 5
- Updated Object panels UI with width expansion enabled
- Fixed issues loading old scenes
- Removed Material button in Vectron
- Updated vectron operators and primitives to support Instances and References, multiple materials, Object layers
- Fixed conflicting parameter named "name" of Color vertex attribute and Float vertex attribute: renamed "attributeName" for MAXScript access.
- Fixed crash in OSL texture import from localDB
- Fixed crash in Unit Volume
Changes of the 13.02 version
- Updated to Octane Render 2022.1 XB1
- Added features of 2022.1 XB1: Vectron primitives, Vectron operators, Field textures, etc...
- Fixed VDB cloud point display in max viewport with non ansi filenames
- Fixed missing updates in Quick mode for non movable proxy objects
- Fixed crash with non ansi VDB filenames
- Added support for Phoenix particle texture (Wetmap, ...) - see tutorial: https://render.otoy.com/forum/viewtopic.php?f=27&t=79688
- Updated Octane Multi-Texture (sorting images by filename, drop to image list)
- Fixed Octane light UI when using Expand Dialog Width option
- Fixed crash with Layer Group
Changes of the 13.01 version
- Updated to Octane Render 2022.1 XB0
- Added features of 2022.1 XB0: Photon tracing kernel, Standard surface material, Standard volume, ...
Changes of the 12.16 version
- Updated to Octane Render 2021.1.4
- Added multiple rollout to most materials and some textures, matching Octane Stand-Alone groups
- Added 'Multi-Texture' to apply several textures randomly. Samples and tutorial comming soon.
- Fixed issue with object instances Motion blur when camera motion blur is disabled.
- Added experimental option to expand object's dialogs to full width Modify panel.
Changes of the 12.15 version
- Added support for 3dsMax 2023
Changes of the 12.14 version
- Updated to Octane Render 2021.1.3
- Fixed Scatter Surface object
Changes of the 12.13 version
- Fixed repeated viewport update when using Motion blur
Changes of the 12.12 version
- Updated to Octane Render 2021.1.2
Changes of the 12.11 version
- Updated to Octane Render 2021.1.1
- Added Texture 'Cinema 4D noise'
- Added back option 'Old volume behavior'
Changes of the 12.10 version
- Fixed missing viewport update when using 3dsMax "Field-of-view" tool
- Fixed option "Use denoised beauty output instead of beauty"
- Fixed Color space option in Image Tile texture
- Fixed issue with osl projection
- Fixed MAXScript bug when clearing Material textures with m.xxx = undefined (eg m.displacement, m.transmission_tex, ..)
- Added attribute generators to be used by multi texture (work in progress)
Changes of the 12.09 version
- Updated Forest pack support (evaluation time, clipping Camera/View)
- Changed default Color space for textures to sRGB. Default also can be changed in Preferences / Material
- Fixed crash when changing Renderer from Octane to non Octane.
- Added support for new Corona 7 materials (Physical, Select, ShadowCatcher)
Changes of the 12.08 version
- Updated UI of Render Setting and Preferences to improve performance.
 (and moved some Kernel options in separate "Render Layer", "Special Passes setup", "Passes Output" Rollups)
- Fixed issues with 4K monitors / Desktop scaling
- Fixed Object not 'Visible to camera' having also no ambient shadow visible.
- Fixed RailClone Object's pivot not included in the instanced geometry
- Added support for Forest Pack clipping View / camera
- Added support for Vectron Union and Substract
Changes of the 12.07 version
- Fixed 3dsMax viewport becoming slow for some scenes with many image textures
- Fixed issue with multiple Octane light instances.
Changes of the 12.06 version
- Fixed sub texture names in Slate editor graph
Changes of the 12.05 version
- Updated to Octane Render 2021.1 RC3
- Fixed objects and lights ambient shadow visibility when Object not set visible
- Fixed performance issue when changing multiple objects instances using the same materials.
- Fixed AOV UI crashes when deleting / moving aov inputs
- Improved naming of AOV default inputs / layer when created from Aov graph or aov dialog
- Improved rendered image performance for viewport display
- Fixed MAXScript renderers.current.viewportMultiPass not updating the pass list
- Fixed OSL dialogs (eg vectron) not showing all parameters with desktop scale > 100%
Changes of the 12.04 version
- Fixed Light mixer not matching Beauty pass
- Fixed AOV UI and AOV Octane graph edition
- Fixed Light shadow visibility when Light not set Visible
- Fixed Universal Camera imager not editable
- Added default kernel settings for Viewport and Render Tone mapping
- Added support of channel flip/swap for NormalBump map and Vray normal map.
- Added default settings for slip/swap Status of NormalBump map and Vray normal map in Preferences
- Added support for scale/rotation of source objects used in ScatterSurface and ScatterVolume
- Improved node selection update when using "Animated Material update in Viewport"
Changes of the 12.03 version
- Fixed issues when rendering with render elements, Cryptomatte, LDR/HDR, EXR
- Fixed RailClone Meshes update in Direct mode. (see the Mesh update type option in Support/RailClone)
- Added RailClone default settings in Preferences
Changes of the 12.02 version
- Updated to Octane Render 2021.1 RC2
- Added display of Octane volume VDB in 3dsmax viewport
- Fixed issues with lights visibility with clay mode
- Added missing Color clay mode
- Fixed rotation of 2D transform
- Fixed texture animation of Composite material
- Fixed Ornatrix hair vertex color RGB order (added setting in Support/Ornatrix)
- Fixed texture update in 3dsmax viewport
- Fixed disabled animated Material update in material editor when texture cache is disabled
- Fixed animated 2D transform UI showing same values for X and Y
- Fixed AOV grah editor changes causing errors or wrong updates
- Fixed saving of Cryptomatte passes, as exr when animated, or as HDR RGB image.
- Fixed render of Cryptomatte passes in LDR with standard render.
- Disabled saving of Deep Image and cryptomate with normal Render, when Save file is unchecked.
- Fixed Rendering of Render Elements passes
Changes of the 12.01 version
- Updated to Octane Render 2021.1 RC1
- Added support for new features of 2021.1
- Improved support of Environment maps [see details there https://render.otoy.com/forum/viewtopic.php?f=27&t=78198]
- Fixed loading of materials with invalid textures from some old scenes.
- Updated render AOV system and dialog
- Replaced custom drop down category buttons by standard 3dsmax rollups for some objects (scatter surface, scatter volume)
- Added support for normal / bump map from Physical material
- Fixed issues with OCIO
- Updated default type of some material's textures to be Color instead of None
Changes of the 11.10 version
- Updated to Octane Render 2020.2.4
- Improved support of Environment maps [see details there ...]
Changes of the 11.09 version
- Updated to Octane Render 2020.2.3
- Fixed saving HDR as EXR without ocio config file, not using imager's LUT
- Fixed AOV info passes not automatically enabled when using 'normalized' versions of info passes
Changes of the 11.08 version
- Updated to Octane Render 2020.2.2
- Added support for Ornatrix vertex color
- Added vertex attribute Name selector in Color and Greycale vertex attribute texture.
- Added fix of invalid Material layers, when loading scene with corrupted materials.
- Updated AOV dialog, added missing Undo, Redo, moved layer scale and color on the single layer line
- Added Render pass settings in AOV scene settings
- Fixed White balance update from render settings's camera dialog
Changes of the 11.07 version
- Added support for 3dsmax 2022
- Fixed enable/disable of AOV layers causing the render to restart
- Fixed issues with EXR background for AOV image
- Added support for tyFlow particle Age. (Octane geo Modifier / tyFlow / particle UID). Use a Instance range texture with Maximun ID set to the frame count.
- Fixed issues that prevented to connect some UV transform (3D, scale, rotation,..) to some Image textures.
- Removed automatic creation of 2dTransform UV when creating Alpha Image, Greyscale Image and Tile texture (as for the RGB Image in previous release).
- Removed Quick update and Multi pass buttons from the viewport. Those are now enabled by default. Use Preferences/Viewport to revert if needed.
Changes of the 11.06 version
- Updated to Octane Render 2020.2.1
- Added a Light mixer tool in AOV settings to automatically create AOV output with layers for Light IDs from the scene objects
- Added option in AOV Image layer to use 3dsmax viewport Background image
- Updated AOV setting dialog with context menus to move layers and inputs up and down, etc
- Updated Material conversion from standard composite texture to Octane composite texture
- Updated Material conversion from Vray Blend material to Octane composite material
- Added categories to Octane textures to match SA organization in Material Browser
- Updated OCIO for EXR export (added Color space / look, ..)
- Fixed OCIO update in Octane camera
- Fixed crash with volumetric Spotlight
- Fixed 4K desktop scaling UI issues with some textures, Volume modifier, Octane geometry modifier
- Fixed animated textures not updated to viewport while draging timeline
- Fixed 'min display sample' for viewport camera
- Removed automatic creation of 2dTransform UV when creating a new RGB Image. (can be re-enabled in Preferences/Troubleshooting)
Changes of the 11.05 version
- Updated Composition texture
- Updated AOV dialog to support animation
- Fixed issues with AOV settings
Changes of the 11.04 version
- Added editable names to inputs and layers of AOV settings
- Added Move up / down to AOV layer's context menu.
- Added Octane graph edition buttons in AOV settings.
- Automatically adding the render passes that are needed by AOV inputs in viewport, main render and orbx export.
- Fixed scatter object translation parameter having y,z components swapped, and not using 3dsmax distance units
- Added scatter object context menu on object parameters, with a Clear option.
- Fixed scatter object UI update.
- Fixed Vectron UI, boolean checkbox not visible.
- Fixed Vectron parameters, having empty name in Curve editor.
- Fixed Vectron parameter update, when using Undo/Redo
- Fixed Scatter Surface and Volume parameter update, when using Undo/Redo
- Fixed crash that can happen when adding a Octane Geometry modifier.
- Fixed crash when disconnecting a texture from the displacement mixer in Slate mode.
Changes of the 11.03 version
- Fixed issue in the AOV settings with Blend mode and Blend operation parameters not working
Changes of the 11.02 version
- Updated to Octane Render 2020.2 RC6
- Added AOV settings.
- Added Scatter surface object.
- Added Scatter volume object.
- Updated Composition texture.
- Fixed issues with UI scaling (4K monitor)
Changes of the 11.01 version
- Updated to Octane Render 2020.2 RC3
- Added OCIO system. See Octane preference to set an OCIO config file, and the OCIO settings in camera imager.
- Added control of hardware ray tracing. See Device settings.
- Added nested dielectic option and material priority.
- Added Spotlight distribution texture.
- Added Composition texture.
- Added Textures: Channel pick, Channel merge, Channel map, Channel invert.
- Added Textures: Ray type pick, Chaos.
- Added Octane Geometry primitives.
- Fixed occasional missing post initialization, resulting in inactivated maxscript commands.
- Fixed missing scrollbar in some combo.
- Fixed incomplete list of channel type for Info channel Kernel.
Changes of the 10.20 version
- Fixed TyFlow issues with motion blur
- Updated Vray material conversion with better support of Glossiness (See options in Global settings, VRay tab)
- Fixed standard NormalBump texture, incorrectly connected to Bump pin instead of Normal pin.
- Fixed usage of both normal and bump for NormalBump and VRayNormalMap. Note that Mix textures is supported when used in normal/bump slot, but a Mix of NormalBump is not supported.
- Fixed bug causing messages '.. set array in attribute of wrong type' and out of memory error.
- Fixed crash when trying to select the root node from an Object layer helper
- Fixed crash with Corona material conversion using Displacement
- Fixed orbx export with Ortho view.
- Fixed loading of older scenes, that could reset tonemapping to linear
- Added Octane Preset helper object to keep material conversion setting and other settings in non octane scenes. (see description and samples here: https://render.otoy.com/forum/viewtopic.php?f=27&t=76178)
- Renamed Octane User Settings / Octane Global Preferences as Octane Preferences.
Changes of the 10.19 version
- Fixed Forest pack motion blur when using motion blur steps > 2
- Fixed missing setup of motion blur settings on multiple rendering with normal renderer.
- Fixed un-necessary rebuild of mesh with some node manipulation while rendering in viewport
Changes of the 10.18 version
- Fixed subdivision in Octane geometry modifier with non movable proxy (now internally set to movable)
- Updated MaxScript support For orbx export. See updated maxscript post: [https://render.otoy.com/forum/viewtopic.php?f=27&t=62173]
- Updated Ornatrix support (update viewport when changing options in Support tab, fixed switch from non movable to movable proxy, ..)
- Updated Orbx proxy object with better support of instances;
- Fixed crash with Hair and Fur and other plugins, related to Broadcast messages.
- Fixed issues when adding modifier while rendering in viewport, and using Undo / Redo
- Changed default Imager response curve to sRGB  (cf Global preference / Kernel default tab)
Changes of the 10.17 version
- Updated to Octane render 2020.1.5
Changes of the 10.16 version
- Fixed missing viewport update when hiding/showing sun lights (eg Octane dayLight) with Quick Mode.
- Fixed missing viewport update when changing Object Layer Helper parameters with Quick Mode.
- Added object list in Object Layer Helper, for objects matching layer ID and baking ID
- Fixed context menu for Quick export, incorrectly hidden if Multi passes was disabled.
- Fixed issue with texture Drag and drop in material editor
- Added support for standard vertex color map in material conversion / 'on the fly' conversion. Note that an Octane geometry modifier may need to be added to objects to read additional map channels.
- Fixed material conversion of vrayNormalMap, now separated to normal and bump pins of Universal material
- Fixed material conversion of bitmap gamma, now set to 1.0 when used as Specular, Opacity, Reflection, etc.. (option in Global preferences / tab 'Vray/Corona/std')
- Update material conversion dialog and added progress / status message.
- Added 'Target focus' mode for Universal camera
- Fixed UI scaling issues for Octane Light (4K monitor, Windows display scale)
- Fixed invalid class names for MaxScript usage (-> '_2D_transformation()' and '_3D_transformation()', see option 'Fix Non Standard internal class names' in Troubleshooting of Global preferences)
- Fixed hidden object state change undetected while not rendering
- Improved support of Vertex Paint modifier, to handle any map channel, without the need of adding the Octane geometry modifier
- Fixed issues when converting material with the classic material editor opened, not updating correctly the current slot.
- Changed the default Movable proxy settings to be Enabled.
- Added option to keep material layer group empty on creation. (Global preference / Material tab: 'Create empty material layer group' )
Changes of the 10.15 version
- Added direct access to relevant standard max object properties in Octane object properties (eg visibility, Cast Shadows, ..)
- Fixed geometry update issue when deleting / adding modifiers, eg Octane Geometry Properties
- Fixed special octane geometry usage with Octane Geometry Properties modifier
- Fixed motion blur object settings update while rendering
- Fixed motion blur steps
- Fixed velocity channel in Octane object properties discarding map ID 1.
- Added Generic velocity scale ('Support' tab), for use of motion blur with velocity maps, as value units may varies with plugins generating those maps. Note that too big values may result in Octane hanging.
- Updated Octane light UI to use 2 lines for size parameters.
- Added conversion of Physical Material
- Fixed occasional crash in material conversion
- Fixed loading of old scenes with 'Non linear tonemapping' disabled, missing to set response curve to Linear/Off
- Added Quick export in viewport context menu of Octane node viewer button (single frame orbx export)
Changes of the 10.14 version
- Updated to Octane render 2020.1.4
- Fixed vectron geometry input node, not re-initialized correctly on rebuild scene.
- Updated vectron geometry input node to use node object layer settings
- Fixed material editor UI issues when loading old max file with image texture having an invalid image type.
- Fixed Octane light class name for maxscript usage : reverted back to "OctaneLight" instead of "Octane Light"
Changes of the 10.13 version
- Added Tone mapping settings in Kernel tab, for viewport and main Renderer. LDR allows to view cryptomate simplified colors. Note that the setting is also available in viewport's pass selection button
- Updated Octane Light to support target mode, color texture; improved UI and viewport display
- Fixed Octane Light On/Off not updated
- Fixed Vectron UI issues and support for geometry input parameter
- Fixed upsampling settings in Octane Camera's imager (none, 2x2, 4x4)
- Updated animated sequence files system for image files and Octane Volume files, with support of loop, ping pong types.
- Added support for ifl files for Octane Volume's animated vdb file list.
- Fixed image filename not displayed in Material editor when file is not found.
- Fixed viewport refresh on some kernel settings change (gamma hack)
- Fixed RTX Enabled checkbox, occasionally not matching the internal setting.
- Added P2P memory usage display in viewport statistics when RTX is enabled.
- Fixed movable proxy test of 'visible to camera' and 'cast shadow' node setting
- Fixed texture dialog in material editor, not updated correctly when changing to another texture slot of same type
- Fixed undo/redo for material editor and volumetric light
- Fixed some material parameters not imported correctly from LiveDB
Changes of the 10.12 version
- Updated to Octane render 2020.1.3
- Added Volumetric Spotlight
- Added Universal Camera
- Fixed RTX enable option not saved as global setting, and not updated when changed from Octane device setting window
- Fixed Camera and Light target position not set correctly when turning on target mode
- Fixed octane light instances when changing vectron mode while rendering in viewport
- Fixed export of some animated textures (3d transform, projection, displacement, etc)
- Fixed Kernel pixel grouping settings.
- Set unique names to object layer nodes, for render pass CryptoObjectNode
Changes of the 10.11 version
- Added a default 'Use Only Standard Particle' setting for tyFlow in Global preferences
- Added a default Kernel setting for gpu headroon in Global preferences, changed from 100 MB to 512 MB.
- Fixed crash in Material Editor with some textures (OSL, Displacement vertex mixer, ..)
- Fixed Octane Object properties, not displaying the Light flag checkboxes when Notify Object on render is set to 'Per object'
- Fixed UI not fully visible with Windows desktop scalling >= 125 % for Kernel / EXR compression file type combo box.
- Fixed Image sequence UI with start frame incorrectly updated
Changes of the 10.10 version
- Updated tyFlow support: Particle orientation with motion Blur, Material override per particle
- Fixed issues with tyFlow particle motion Blur.
- Added support for tyFlow particle Mesh velocity for motion blur
- Added option in tyFlow Support Tab and global preferences to always set tySplines as movable proxy
- Added option in tyFlow Support Tab and Octane geometry Modifier to use standard particle interface only (allows to render from particle Shape without Mesh operator)
 Note that this is for backward compatibility; it is preferable to add a Mesh operator when needed.
- Added option in Octane Properties context menu to display external Object details (tyFlow objects)
- Fixed Material editor scale issue with Windows Scale and layout set to 125%
- Fixed toggle 'Enable displacement map' in Kernel
Changes of the 10.09 version
- Fixed occasional crash with some tyFlow simulators
Changes of the 10.08 version
- Updated to Octane render 2020.1 RC4
- Re-added support for 3dsMax 2013,2014
- Fixed Octane Light with Vectron mode failling to connect a Transmission texture
Changes of the 10.07 version
- Added support for 3dsMax 2021
- Removed support for 3dsMax 2013, 2014
- Updated to Octane render 2020.1 RC3
- Added default texture size used when Material conversion needs baking texture (Global settings)
- Improved texture conversion for Falloff with curves, Noise , ..
- Added internal Material with Object color when object don't have any material assigned. (to enabled in Global settings, Material tab)
- Fixed converted materials not always re-assigned to objects.
- Added Material 'on-the-fly' conversion support for VRayLight, VRaySun
- Added options to convert only specific materials (selected objects, current in Material editor)
- Fixed converted Material display in viewport and assignments to objects
- Improved standard bitmap support for tilling, real world uvs
- Added more supported materials (CoronaLight, CoronaColor, CoronaTriplanar, CoronaLightMtl, CoronaLayeredMtl, CoronaRaySwitchMtl, CoronaHairMtl, stdChecker, stdTint, ..)
- Fixed issue with UI refresh of OSL Camera, OSL Baking Camera, OSL projection.
- Fixed Hair and fur not rendered when H&F mode is not 'geometry' . See Support tab, Hair and fur panel
Changes of the 10.06 version
- Updated to Octane render 2020.1 RC2
- Added support for Material conversion 'on-the-fly' for most currently supported non-Octane materials and textures
- Improved support for material conversion of falloff textures
- Improved support for material conversion of Output texture
- Added support for vray Car paint Material (experimental)
- Added rendering with default 3dsmax object color, when no material is set.
- Minor bug fixes
Changes of the 10.05 version
- Fixed 2d projection texture issue with second values of scale / transform not editable.
- Fixed incorrect desktop scale (eg, with 4k monitors) in Material editor and for some Kernel settings
- Fixed background environment Color not updated in Octane viewport
- Changed Out of core maximum ram from 128GB to 1024GB
- Removed invalid 'Export material' button in Material layers
Changes of the 10.04 version
- Fixed missing geometry from Forest Pack and other plugins when using XRef objects.
- Changed the range of floating points of texture pins from [0-1] back to [0-100000] (as in previous version of the Material editor UI; but beware that the valid range is [0-1] )
- Moved all broadcast settings to kernel settings. All are now scene specific.
- Fixed update of image textures compression and layer settings.
- Updated Material editor UI for better performance.
Changes of the 10.03 version
- Updated to Octane render 2020.1 XB3
- Added Dirt visibility in Octane Object Properties
- Re-introduced Legacy mode for Forest pack, for simpler backward compatibility with older scenes.
Changes of the 10.02 version
- Fixed update of instances of animated proxy, when using Direct mode.
- Fixed occasionally missing helper buttons in Forest pack support tab.
- Fixed standard particle update with normal render.
- Fixed issues with the viewport 'Rebuild' button.
- Fixed phoenixFD particles for fire simulators
- Fixed crash when phoenixFD creates Omni lights
- Fixed missing update when material assigned to one of multiple instances
Changes of the 10.01 version
- Added support for PhoenixFD version 4
- Fixed missing geometry for some types (Boolean, ..)
Changes of the 10.00 version
- Updated to Octane render 2020.1 XB2
- Added TyFlow support.
- Added RailClone instance support.
- Updated PhoenixFD support
- Simplified Forest pack support settings, with status display and optional change of FP render mode.
- Updated Out of core settings UI, to match Stand Alone names
- Improved material editor dialogs for most materials and textures
Changes of the 9.01 version
- Updated to Octane render 2019.2 XB3
- Added Hair material
- Added RTX acceleration in Device settings, to enable the RTX backend for ray tracing (experimental).
- Added Random walk medium texture
- Updated Dirt texture
Changes of the 8.07 version
- Updated to Octane render 2019.1 RC5
- Added Displacement vertex mixer texture
Changes of the 8.06 version
- Updated Ornatrix support. Added Ornatrix settings in the 'Support' tab, and added new UV channel selection. Those are now saved per scene.
- Fixed crash with automatic baking of standard Bitmap.
  Automatic baking is permormed when a standard Bitmap is used as 'Standard texture' in Octane materials. (This can be disabled in a new setting in material tab, "Always Bake Standard Bitmap")
  This allows support of all Bitmap settings, like Cropping / placement.
Changes of the 8.05 version
- Updated Forest pack support.
- Added 'Support' tab in render settings, for common settings and external plugin configuration. Those are now scene specific, with default values editable in Global preference.
- Moved Network config to the Devices tab
- Updated Particle flow support. Render mode (vs viewport mode) is now read from object properties 'Use render mode', and can be overridden in 'Support' tab.
- Added support for multiple shapes for PFlow, using shape instance: group of objects.
- Updated PhoenixFD : Added setting of particle object layer using particle mesh object's properties.
- Fixed camera FOV update when changing viewport
- Added automatic baking of standard Bitmap used as 'Standard texture' in Octane materials. (This can be disabled in a new setting in material tab, "Always Bake Standard Bitmap").
- Fixed Volume ramp texture changes not updating viewport
- Fixed bugs reading ifl files
- Added Orbx export of animated textures (ifl files)
Changes of the 8.04 version
- Updated to Octane render 2019.1 RC3
Changes of the 8.03 version
- Updated to Octane render 2019.1 RC2
- Renamed Dielectric layer material as Specular layer material
- Removed Coating layer material
- Fixed Forest pack objects using random color.
- Added object layer to Forest pack objects, (using the Octane properties of the scattered object, eg layer ID, light settings..)
Changes of the 8.02 version
- Updated to Octane render 2019.1 RC1
- Renamed Specular layer material as Dielectric layer material
- Added Coating layer material
- Added Cutoff to Post processing settings
- Added Max subdivision of Kernel settings
- Added Motion blur to Octane cameras, to set motion blur parameters per camera. Moved kernel settings motion blur to Camera tab.
- Fixed OSL parameter and shader update and animation (Vectron, OSL cameras)
Changes of the 8.01 version
- Updated to Octane render 2019.1 XB2
- Added Composite material
- Added Shadow catcher material
- Added Vertex displacement texture
- Added Layered material
- Added new Layer materials (Diffuse layer, Specular layer, Metallic layer, Sheen layer, Layer group)
- Added AI upsampling settings to Imager
- Added 'Affect roughness' in Kernel settings.
Changes of the 7.08 version
- Fixed issue with some objects being ignored when not set as movable proxy
- Fixed issue with viewport stopping to update while editing environment texture
Changes of the 7.00 version
- Updated to Octane render 2018 xb2
- Added Vectron object. See Stand Alone documentation and 3dsmax samples to be posted soon.
- Added Volume SDF support. (using a new Type parameter in Octane Volume object)
- Added Cryptomatte passes, and new Save Image options to saved output as EXR file. Standard render also saves additional EXR files.
- Added Texture cache settings in Global settings, Material tab. Note that the texture compression is now internally cached.
- Added Vertex attribute texture maps (Color and Float) and preliminary support of Vertex paint modifier.
- Fixed drag and drop of texture map on osl parameters
Changes of the 6.12 version
- Updated to Octane render 4.01.1
- Added direct save as multi pass EXR from viewport (right click on save image button, exr compression and other settings in Global settings / Viewport )
- Fixed multi tile compression selection when using standard Multitile
- Fixed crash in material converter when a texture image file was not found
- Added Orbx import using new Orbx proxy object. (Animation from orbx not supported yet)
- Fixed missing tga file type when browsing for Alpha Image.
- Fixed render restart in some cases when opening Material editor or browsing texture/material.
- Improved scene loading time when textures are set visible in 3dsmax viewport.
Changes of the 6.01 version
- Updated Octane Renderer to 4.00 XB3
- Added AI Denoiser settings in Camera tab (Render setup), and in Octane camera object, in the Imager section.
- Added Out of core geometry settings in the Kernel tab (Render setup)
- Added AI Light settings in Kernel tab, in the supported kernel panes (Direct light, Path tracing, PMC)
- Added Render Elements for the denoiser passes
- Updated device settings to select GPU(s) for denoiser
Download for users with a Studio / Enterprise subscription license: (VR)
OctaneRender Studio+ 2026.3 for 3ds Max v26.9
DEMO version:
OctaneRender Demo 2026.3 for 3ds Max v26.9 DEMO
The 3dsMax plugin Manual is available there:
https://docs.otoy.com/3DSMaxH/3DSMaxPluginManual.htm
coilbook
There is a bug when you open a scene there is a color tab instead of a numerical value even thought the value is selected.
By the way, We are still waiting for the denoiser to get faster. Not at the end of the render (This works fast at the end. The actual de-noising at the end is fast)—actual render times are 2–3 times longer when it's enabled compared to when it's disabled.
I think you should look into faster de-noising system again. Currently it is useless, especially for animations, when it makes 1 min rendering 3 min where I can do the same with rendering more samples.
coilbook
Hi neonZorglub,
I have a problem with one of the slaves. The PC rebooted and now I cannot install slave daemon anymore. It shows no GPUs even though they are present and just says closing due to hanging up. Worked like a charm before with all versions. Do you know what to do about it?
Also are 6xx drivers any good? Any advise on the most stable recent drivers?
Thank you
Hi neonZorglub,
After doing many tests we found out 2025.3 installs daemon slave great. 2025.5 and up doesn't. Can you look into it? 2025.5 used to work fine not sure what happened. The images are attached.
Pelana001_1
Thanks for this new version.
Windows 11 Pro for Workstations x64, Ryzen 5950x, 128 Gb ddr4 Bus 3600 mghz, Noctua NH-D15, M2 1 Tb SSD WD Black SN850X NVMe 7300 mbps, 8 SSD HP S650 1 TB, 1 RTX A4000, power source Corsair 850 w Platinum Series, mb X570 wifi plus Asus
Pelana001_1
Hello OR team.
I’d like to share an observation: I installed the latest version of OR for 3ds Max (version 2026.3 - 26.9).
It appears in the program's options when selecting the render engine, yet it does not show up in "Programs and Features"—much like version 2026.3 - 26.8, which also didn't appear there.
A folder for version 2026.3 - 26.8 appears in Windows Explorer, but the installed version 2026.3 - 26.9 does not.
I assume this might be a server issue or a bug in the installer.
Do you have any comments regarding this version issue?
Versión 2026.3 - 26.8 appear
version 2026.3 - 26.8 and 2026.3 - 26.9 it does'nt appear
paride4331
coilbook wrote: Wed Jun 24, 2026 7:50 pm There is a bug when you open a scene there is a color tab instead of a numerical value even thought the value is selected.
Hi coilbook,
AO texture: I submitted my report to the developers. Fortunately, this seems to be just a display issue, the value isn't shown, but it's still applied correctly during rendering.
Denoiser: is “Denoise on Completion” is disabled? When this option is off, the denoiser does not run only once at the end of the render; instead, it runs periodically during rendering based on the Minimum Denoiser Samples and Maximum Denoiser Interval settings. Each denoising pass interrupts path tracing and introduces additional overhead. If the interval is set too low, this overhead is incurred repeatedly throughout the render.
If “Denoise Volumes” is enabled even though no volumes are present in the scene, resulting in unnecessary processing. Octane also offers Intel’s Open Image Denoise as an alternative to its native AI denoiser. Depending on the scene, it may produce different results, so it is worth comparing both to determine which performs better for a given project. Another contributing factor could be the edge case where VRAM is fully saturated. In an out-of-core workflow, denoising may become noticeably slower.
paride4331
coilbook wrote: Sat Jun 27, 2026 3:33 am Hi neonZorglub,
Thank you
Hi neonZorglub,
Hi coilbook,
You can try 581.29 Studio, they work fine with Octane.
coilbook
paride4331 wrote: Mon Jun 29, 2026 1:59 pm
Thank you
Hi neonZorglub,
Hi coilbook,
Hi Paride,
nothing works. 2025.3 can install daemon but higher version cannot. The salve was rendering then it rebooted itself and now 2025.5 and up cannot be installed anymore.
paride4331
Hi coilbook,
Did you uninstall all the previously installed Daemons before installing v2026.3 Daemon?
coilbook
paride4331 wrote: Mon Jun 29, 2026 4:02 pm Hi coilbook,
Reinstalling windows fixed it. Thank you
Return to “Releases”
