OctaneRender® 2026.2 for 3ds max® v26.7 - 3dsMax 2027 support
remKa
I've tried every settings available (mb duration, shuttertime etc...), nothing works when the displacement map is there
AMD 9950x3D / RTX 4090 / RTX 3090 / 192 Go DDR5 / Win 11
http://www.remy-kerbiquet.com
neonZorglub
remKa wrote: Thu Jun 04, 2026 1:40 pm I've tried every settings available (mb duration, shuttertime etc...), nothing works when the displacement map is there
Thank you for your scene.
That's very strange.. I'm not sure why, but it seems to work when you change the Texture displacement's Quality from High to Normal !
That could be a bug or a limitation of the Octane Engine.. We will report this issue to the Engine team.
paride4331
Hi remKa,
I've increased the motion blur duration only.
I'm going to test this high/normal option with your original setting.
paride4331
HI,
This is a test with settings that seem to work both with MB enabled only in the kernel and with the Octane Camera in Normal and High modes. Could you please test it and let me know?
MB.zip
(35.61 MiB) Downloaded 3 times
remKa
It's kind of working but only with these weird settings and not as it should (the black disk has motion blur, it shouldn't).
I've always used around 0,5 to 2 MB Duration in Octane with shutter time between 25 and 150, as soon as I put these value nothing is working correctly.
I have correct output when I remove the displacement map, please see this attached file (I'm not crazy ^^ !) :
Enregistrement de l'écran 2026-06-04 172255.mp4
(7.94 MiB) Downloaded 2 times
Return to “Releases”
