OctaneRender® 2026.2 for 3ds max® v26.7 - 3dsMax 2027 support
I've tried every settings available (mb duration, shuttertime etc...), nothing works when the displacement map is there
AMD 9950x3D / RTX 4090 / RTX 3090 / 192 Go DDR5 / Win 11
http://www.remy-kerbiquet.com
- neonZorglub
Thank you for your scene.remKa wrote: Thu Jun 04, 2026 1:40 pm I've tried every settings available (mb duration, shuttertime etc...), nothing works when the displacement map is there
That's very strange.. I'm not sure why, but it seems to work when you change the Texture displacement's Quality from High to Normal !
That could be a bug or a limitation of the Octane Engine.. We will report this issue to the Engine team.
- paride4331
Hi remKa,
I've increased the motion blur duration only.
I'm going to test this high/normal option with your original setting.
- paride4331
HI,
This is a test with settings that seem to work both with MB enabled only in the kernel and with the Octane Camera in Normal and High modes. Could you please test it and let me know?
- MB.zip
- (35.61 MiB) Downloaded 57 times
It's kind of working but only with these weird settings and not as it should (the black disk has motion blur, it shouldn't).
I've always used around 0,5 to 2 MB Duration in Octane with shutter time between 25 and 150, as soon as I put these value nothing is working correctly.
I have correct output when I remove the displacement map, please see this attached file (I'm not crazy ^^ !) :
- Enregistrement de l'écran 2026-06-04 172255.mp4
- (7.94 MiB) Downloaded 87 times
- paride4331
Hi remKa,remKa wrote: Thu Jun 04, 2026 3:23 pm It's kind of working but only with these weird settings and not as it should (the black disk has motion blur, it shouldn't).
- neonZorglub
The problem comes from the use of vertex motion blur. The displacement texture seems to be incompatible with the velocities of each vertex..paride4331 wrote: Fri Jun 05, 2026 6:58 amHi remKa,remKa wrote: Thu Jun 04, 2026 3:23 pm It's kind of working but only with these weird settings and not as it should (the black disk has motion blur, it shouldn't).
But a Vertex displacement works fine. It just needs a lot of vertices on the object to get a good resolution.. use the Subdivision level for that, or some modifiers..
Here is your updated sample:
Hello NeonZorblug, is there anything you can do about it or is it a standalone limitation ?
- neonZorglub
It seems to be a standalone limitation. I could reproduce the issue with a more simple case, without tyFlow and will check with the engine team.remKa wrote: Fri Jun 05, 2026 2:15 pm Hello NeonZorblug, is there anything you can do about it or is it a standalone limitation ?
For now, the best option is to use the Vertex displacement texture, with Subdivision level ~4 , that gives very close result and works fine with vertex motion blur..
EDIT:
This has always been a limitation of texture displacement and actually one of the reasons vertex displacement was implemented.
https://docs.otoy.com/standaloneSE/TextureDisplacement.html
BUG:
OctaneLight has no size when opening a scene from Octane 2025. But it is displayed with proper size in viewport. Had this in several files now.
PURE3D Visualisierungen
