Ocio isn't working
Pelana001_1
Hello OR team, I followed the setup instructions in a video to use Ocio, but when I select the Octane Viewport option, I get an error message.
What could be causing this error?
Thanks, OR team.
Ocio isn't working
Ocio isn't working
Windows 11 Pro for Workstations x64, Ryzen 5950x, 128 Gb ddr4 Bus 3600 mghz, Noctua NH-D15, M2 1 Tb SSD WD Black SN850X NVMe 7300 mbps, 8 SSD HP S650 1 TB, 1 RTX A4000, power source Corsair 850 w Platinum Series, mb X570 wifi plus Asus
paride4331
Hi Pelana001_1,
Are you sure you downloaded the right library and set up all the OCIO package folders correctly?
Pelana001_1
Hi, I downloaded the file from the Open Color homepage, here's the link.
https://opencolorio.readthedocs.io/en/latest/quick_start/for_artists.html
paride4331
Hi Pelana001_1,
https://github.com/AcademySoftwareFoundation/OpenColorIO-Config-ACES/releases
cg-config-v2.2.0_aces-v1.3_ocio-v2.4.ocio
Return to “Autodesk 3Ds Max”
