PhoenixFDOceanTex
Pelana001_1
Good evening OR team, I'd like to know if there's a way to extract the Phoenix maps or how to implement the maps in the image in 3ds Max 2027, since there's no official installer for Phoenix.
I understand there's no support for newer versions.
Does OctaneRender have any way to recreate the PhoenixFDOceanTex map? Because honestly, I only use that map for ocean rendering.
Thank you, OR team, if you could provide an answer.
Reference image attached.
PhoenixFDOceanTex
PhoenixFDOceanTex
Windows 11 Pro for Workstations x64, Ryzen 5950x, 128 Gb ddr4 Bus 3600 mghz, Noctua NH-D15, M2 1 Tb SSD WD Black SN850X NVMe 7300 mbps, 8 SSD HP S650 1 TB, 1 RTX A4000, power source Corsair 850 w Platinum Series, mb X570 wifi plus Asus
paride4331
Hi Pelana001_1,
Ocean.zip
(947.9 KiB) Downloaded 53 times
paride4331
paride4331 wrote: Wed Apr 29, 2026 10:24 am Hi Pelana001_1,
Ocean.zip
Pelana001_1
Hello paride4331, you are so kind to response quickly.
I was wondering if you know whether the Phoenix plugin is available for 3ds Max 2027, as I understand it's discontinued.
And if there's any way to mimic or simulate those parameters in the OR options.
Thank you so much.
paride4331
Hi Pelana001_1 ,
The file contains a scene with an ocean map texture and particles, rendered using Octane Render.
Pelana001_1
Thanks for sharing this Paris 4331 dinner; that's what I meant. The PhoenixFDOceanText map doesn't appear in the final render because I don't have the Phoenix plugin for 3ds Max 2027.
It's because the plugin has been discontinued for newer versions.
That's why I'm wondering if it's possible to recreate the realistic infinite water effect in OR. I know I can use OR's infinite plane, but the challenge lies in controlling the wind: speed, height, displacement, etc.
No water and No PhoenixFDOceanText map
Pelana001_1
This image it's done with Inf. Plane and a simple material water and Noise Texture by OR in the option of Bump.
Inf. Plane
Inf. Plane
paride4331
Hi Pelana001_1,
OceanTxt works fine, did you run the sim before to render?
Pelana001_1
Good evening OR team, is there a way to load the PhoenixFDOceanTex map directly, as it does in Corona Renderer?
Because no matter how many tests I've done, I can't get an ocean image in OctaneRender. It's very complicated to use combined materials, and the result isn't what I expected.
In Corona Renderer, you just load the map PhoenixFDOceanTex in Displace mode, apply the displacement values, and that's it realistic ocean water.
Thanks, OR team.
PhoenixFDOceanTex in Corona Renderer
Pelana001_1
In this image isn't displacement PhoenixFDOceanTex with OR
PhoenixFDOceanTex in OR
Return to “Autodesk 3Ds Max”
