If you go in preferences and unload the plugin blender 5.1 crashes, that with 36.1
I noticed as i use an addon to load unload plugins.
Thank you
Crashing Blender
C. RAM Capacity (i.e. 6 GB)
- linograndiotoy
Do you mean 31.6?
I uninstall the addon each time I upgrade to a new version.
That's the order of operations I perform:
- launch the server
- launch Blender
- disable the Octane Addon
- uninstall the Octane Addon
- install the new version
- close Blender
- open Blender
Never got a crash.
Could you please describe your steps and the version you're using (Blender 5.1 only works with 31.6)?
- launch the server
- launch Blender
- close Blender
- open Blender
Never got a crash.
Blender 5.1.1 with octane 31.6.0
It does that crash even with all other addons disabled.
crashlog attached
Thank you
crashlog attached
Thank you
- blender.crash.txt
- (120.18 KiB) Downloaded 29 times
- linograndiotoy
Are you using the OpenGL backend? Do not use Vulkan.
- linograndiotoy
I've tried several times here, no crashes.
I noticed this in your log:
Substance 3D addon for Blender: Substance Tools Connect Success [0.0015 seconds] - Application [Blender] with process id [25476] and port [56482] is now connected to the Substance Integration Tools # Info
Substance 3D addon for Blender: Addon Server Start Success - Substance Addon Server started running in port [56482] # Info
Can you please try to disable this?
Also, are you absolutely sure you're using the right server?
Be sure to download both the server and the addon from this page (for the most updated addon, please look into the last reply to the post):
viewtopic.php?t=85592
Lino I disabled all , deleted the octane from scripts , reinstalled it and had only octane active.
restarted blender with opengl, tried to diable octane , crashed.
I just after seeing this I send you the log with all plugins,
If you want i can clear the crash log and send you the generated crash log with octane only.
Disregard , I made a backup of my local roaming and uninstalled blender.
So i started with no previus local profile , Installed blender again and added just octane. (profile started as new)
It works, so i will try to figure out what was wrong in my backup profile I had kept as backup, if found smth I will post.
Solution ,
dunno why, it was my startup.blend that i use from 5.0 version.
deleted c:\Users\dinos\AppData\Roaming\Blender Foundation\Blender\5.1\config\startup.blend
started blender / enabled all addons / saved startup and fixed, now I can enable disable octane, and with all addons I had loaded.
The only thing that bothers me is I have to go through every option I had in my custom startup and change them...
Thank you for listening
Konstantinos
Konstantinos
