Can't run Octane Server 2026.1-31.3-beta on Fedora Linux
Silverwing
Hey there.
I downloaded The new Blender "OctaneBlender Addon 2026.1 - 31.3 Beta Release (for Blender 5.0) [TEST]"
I can extract and run the "octane_addon_server-studio-31.3-beta.zip" on Windows just fine.
But on my Linux Fedora 43, when I extract and run "OctaneStudio_for_BlenderOctaneAddon_Linux_2026.1-31.3-beta.zip"
I get following error:
libpng error: unexpected zlib return code
Segmentation fault (core dumped) ./OctaneServer
In contrast, when I install the latest "OctaneRender™ for Blender 2024.1.2 - 29.20" "octane_server_studio_2025.4-30.8.0-stable.run"
It installs and runs just fine.
There seems to be a difference between the newer extracted version of OctaneServer and the older .run installed one.
Would it be possible to offer a version of the OctaneServer that again will run on Fedora.
Thank you!
WIN 11 PRO 64 | ASUS X299 SAGE | 1X RTX 4090 3X RTX 3090 | i7 10980XE | 128GB RAM
linograndiotoy
I'll ask the developer!
linograndiotoy
Hey Raphael,
The developer has a question for you:
"About the Linux version issue, the user said "OctaneRender™ for Blender 2024.1.2 - 29.20" "octane_server_studio_2025.4-30.8.0-stable.run" was working fine, which refer to 2024 and 2025 versions at the same time - so I don't know which one is correct? Or maybe both of them are working? Can you please help me ask him/her to clarify it for me? Did the custom-built versions work for him but the add-on versions didn't work?
Thanks!"
Please let us know, thanks!
Silverwing
Hey lino,
sorry for getting back to you so late. The answer notifications both went into my spam folder 😇
Also I seem to have mixed up some versions in my original message.
Basically what I am saying is, the Octane Server for Linux that came with a .run package that could be installed works just fine.
For the Addon Version of Octane for Blender the "OctaneServer - Linux - Studio Edition" comes as a .zip file that simply extracts. No .run package that installs Octane Server.
So in short:
It's about the Octane Server on Fedora Linux 43
I can install and run the .run packages of the Octane Server just fine.
I can't run the extracted .zip package
When I start "Octane Server" with ./OctaneServer from the extracted zip. The terminal returns:
P.s. when I try the same thing on Linux Mint 22.3 it works and I get a Otoy sign in Popup for Octane Server.... maybe it has something to do that Mint is running on X11 still but Fedora on Wayland?
Thank you for looking into this!
Cheers,
Raphael
linograndiotoy
Hi Raphael,
Thanks for your reply!
Could you please try the following command and see whether it resolves the issue?
For example:
patchelf --set-rpath '$ORIGIN/lib' ./OctaneServer
This forces OctaneServer to load the bundled libraries from its local folder, similar to what the .run installer does.
If this does not fix the problem, could you please compare the shared library dependencies between the working .run installation and the extracted .zip version and send the results back to me?
You can use the following commands:
readelf -d ./OctaneServer | grep NEEDED > needed.txt
ldd ./OctaneServer | sort > ldd.txt
Running these for both versions and sending the outputs would help us identify any dependency differences.
Silverwing
Hey Lino,
thank you for getting back to me,
I had to install the patchelf package first.
I tried patchelf --set-rpath '$ORIGIN/'lib ./OctaneServer
Probably because there is no "lib" folder in the directory. The .so files sharing the same folder with the OctaneServer
The attached screenshot shows the folder structure of the unpacked OctaneAddonServerStudio directory.
I tried altering the path to:
patchelf --set-rpath '$ORIGIN/' ./OctaneServer
and
patchelf --set-rpath '$ORIGIN' ./OctaneServer
without luck. The terminal does not provide any output and ends the program (just jumps to the next line)
Though when I tried to just run ./OctaneServer it gave me a bit of a different output then last time. I am guessing due to some library updates in Fedora in the meantime:
Last but not least I ran the other two commands
and also attached those .txt files to the message.
Hopefully this will get us somewhere.🤞
ldd.txt
(1.98 KiB) Downloaded 75 times
needed.txt
(723 Bytes) Downloaded 67 times
Silverwing
Bumping this thread because it still does not work with the latest Server:
Octane Server 2026.1-31.4
Might I suggest an installer like in the previous non plugin versions.
Thank you in advance for looking into this!
linograndiotoy
We're on it, but it will require some time.
Silverwing
Thank you very much for your reply. I really appreciate that you work on it 🙌
If I achieve a fix on my end, I will let you know!
DrawFun
Hi Raphael,
Thanks again for the detailed logs. We prepared a test build of the Blender addon Octane Server package with a few Linux runtime libraries bundled locally, so it should no longer use Fedora’s system versions for those specific libraries.
It's an updated server for 2025.6. viewtopic.php?t=85603
I’ll send you the new .zip via PM.
Could you please try it like this?
unzip OctaneAddonServerStudioUpdated.zip
cd OctaneAddonServerStudioUpdated
ldd ./OctaneServer | egrep 'libz|libpng|libgomp|liboctane'
./OctaneServer
In the ldd output, please check that these resolve from the extracted folder, not from /lib64:
libz.so.1
libpng16.so.16
libgomp.so.1
liboctane.so
If it still crashes, please send back the terminal output from:
LD_DEBUG=libs ./OctaneServer 2>&1 | grep -E 'libz|libpng|libgomp|liboctane'
Cheers,
Tom
Return to “Blender”
