Is it possible to extract the geometry.abc out of the ORBX?
Terryvfx
Recently worked with an artist that let's say could had done a better job, only thing I have is an .orbx ready to render but I only want the animations that are in the .abc file to salvage some stuff, is this possible? if so how?
Yes, you can!
Open the .orbx scene in Standalone, then go to menu File/Unpack package, choose a destination and hit OK.
An "assets" folder will be created in the chosen location, with all geometry and texture nodes used in the scene.
ciao,
Beppe
Terryvfx
thanks!
p3taotoy
Bepe
I have a diff issue :>))
I have an ABC file in the standalone that works. Yaaaaa!!!
(I have tried IMPORTING the same ABC file into blender and maya and it is unable to import. This could be because the abc exporter from Daz Studio 3d is a bit flakey :>)))) So I am guessing the Daz "type" of abc file is compatible with octane standalone but not other apps.
So I thought I would try exporting (the abc that works in the standalone)... out using the geometry exporter node/script:
I saved out to an abc and fbx Sucessfully
Then re-import them to octane standalone, maya and Blender as a test (They successfully come back in all the apps) but they only export a file abc or fbx with no animation.
Any ideas mate? (Put the orbx file in here if it helps)
Best
Peter
ORBXPackageforBepe.orbx
(62.04 MiB) Downloaded 105 times
Hi Peter,
Your ABC file is opening without issues in C4D, so I have exported it again in ABC format from C4D:
Then imported back in Standalone without issues:
Please try with the following version and report back, thanks:
Horse_Bep_ABC_from_C4D.zip
(16.19 MiB) Downloaded 109 times
ciao,
Beppe
p3taotoy
Thats good to know it works in Cinema Bepe. Thanks.
Are you able to export it from the standalone using the geometry node and create a NEW ABC node that has animation in it?
I am trying to ge an ABC into Blender that I can use a particualr addon with. So it has to work in blender and my original from daz does not thats why I was trying to re-export it out from the standalone to see if it would then go into blender.
Would you mind re-exporting it from Cinema (I do not own that one) and sending that to me.... OR is there a way to use the geometry node to get an ABC and not just a still mesh as I have been getting from the standalione??
Thanks mate
Peter
p3taotoy
I realize my more simple question might be..
When you use geometry exporter on an abc file and write out an abc file... does it include the animation?
or
If you unpack it... does it rewrite anything or just "unpack" originals.
Secretly hoping Octane's rewriting of the abc fixes the issue of not being able to import my original abc into blender. Trying to use octane to fix someone elses issue :>))
:D :D
Hi Peter,
If you unpack the latest .orbx scene I have shared, you get the horse exported from C4D.
About Geometry Exporter node in Standalone, I don't think it is designed for animated geometry export.
Unfortunately I'm not good in Blender, but I'm sure that it can import animated ABC files without issues.
Have you tried to ask this question in Blender section?
viewforum.php?f=32
ciao,
Beppe
p3taotoy
Perfect... that did it mate!!
So Daz essentially writes out an incomplete ABC
Cinema and Octane together must be "completing it in in some fashion.
I'll reach out to Daz
MANY Thanks Beppe
Peter
