Controlling OSL shader colors
SKY2SART
Hello ! I'm trying to find a way to control the colors of the "PaintColors" OSL shader, but so far everything i tried didnt work out.
What i'm trying to do is to remove some of the colors, only to keep blue/pink hues; is that possible or do i have to find a workaround in post ?
So far I tried to remove the colors I dont want by driving the OSL shader into an octane gradient, but it doesnt give any good result as it usually make the gradient less "smooth"
Thanks in advance !
//reference: http://glslsandbox.com/e#43216.0
shader paintColors(
		float tm=0[[float min=0, float max=100]],
	  float offX=0.175[[float min=0, float max=0.5]],
	  float offY=0.275[[float min=0, float max=0.5]],
	  float offZ=0.25[[float min=0, float max=0.5]],
    output color c = 0)
    int   complexity      = 47;    // More points of color.
    float fluid_speed     = 108.0;  // Drives speed, higher number will make it slower.
    float clrInt = 0.8;
    vector p=vector(u,v,0);
    p=P;
    for(int i=1;i<complexity;i++)
        vector newp = p + tm*0.001;
        float s=i;
        newp[0]+=0.6/s*sin(s*p[2]+tm/fluid_speed+0.3*s) + offX; // + mouse[1]/mouse_factor+mouse_offset;
        newp[1]+=0.6/s*sin(s*p[0]+tm/fluid_speed+0.3*(i+10)) - offY; // - mouse[0]/mouse_factor+mouse_offset;
        newp[2]+=0.6/s*sin(s*p[1]+tm/fluid_speed+0.3*s) + offZ;
        p=newp;
    c=vector(clrInt*sin(3.0*p[0])+clrInt, clrInt*sin(3.0*p[1])+clrInt, clrInt*sin(p[0]+p[2])+clrInt);
A solution can be to multiply or divide each single RGB component in the final c vector color.
In the following example, I have multiplied the Red and Blue components by 4, and divided the Green component by 100:
shader paintColors(
    output color c = 0)
    float clrInt = 0.8;
    p=P;
        float s=i;
        p=newp;
    c=vector((clrInt*sin(3.0*p[0])+clrInt)*4, (clrInt*sin(3.0*p[1])+clrInt)/10, (clrInt*sin(p[0]+p[2])+clrInt)*4);
ciao,
Beppe
SKY2SART
Hi ! Thanks for your reply.
This is going in the right direction definitely, but i'm realizing that since white is the combination of the 3 primary colors, it won't work that way...
Maybe I should just look for another OSL shader to realize that effect, or just do it in post by removing green and yellow hues directly there
Thanks anyway !
