How do i render Tracer object with C4D hair shader controls?
what i want to do is taper the start and end of each path/spline generated by the tracer object. I can use the Octane object tag and turn on "render as hair" and use an octane shader but the Octane hair tag doesn't give a graph to control hair thickness along the length of the curves. The c4d hair shader offers this thickness control but doesn't seem to work on a tracer object, only a hair generator. is there a way to set this up in octane?
Rod
Asus P6T Deluxe V2
Intel core i7 920 (2.66 GHz quadcore)
12 gig RAM Kingston HyperX
BFG GTX 285 OCX
CPU cooling - Noctua NH-U12P SE2
OCZ Vertex Turbo 120 GB Sata II SSD
Windows 7 Ultimate 64bit
Asus P6T Deluxe V2
BFG GTX 285 OCX
maybe not obvious is that i want to avoid setting up a sweep for memory consumption. it brings the system to a crawl.
I'd love to control the sweep size along the paths at rendertime using the tracer object.
Rod
Asus P6T Deluxe V2
BFG GTX 285 OCX
Asus P6T Deluxe V2
BFG GTX 285 OCX
With this method you can just define root/tip thinkness. You can use to generate it as hairs and render. It will directly render the hairs without using object tag method.
Octane's object tag allows root/tip thickness yes. but it doesn't allow more control to allow a thin root, fat body, thin tip.
like this image. the C4D hair shader allows this for the hair generator and Octane will render it. but I can't apply that hair shader to a tracer object. it doesn't seem to work.
so...I'm wondering if there's another way to get this control.
Rod
Asus P6T Deluxe V2
BFG GTX 285 OCX
Asus P6T Deluxe V2
BFG GTX 285 OCX
the idea came from seeing this control in Redshift. Rendertime splines is the only way to handle this efficiently with many particles
Rod
Asus P6T Deluxe V2
BFG GTX 285 OCX
Asus P6T Deluxe V2
BFG GTX 285 OCX
I'll add something like that if there's not really a way to convert tracer data to hairsrodney71 wrote:the idea came from seeing this control in Redshift. Rendertime splines is the only way to handle this efficiently with many particles
that sounds amazing and i can't wait to test that out. thanks for commenting
Rod
Asus P6T Deluxe V2
BFG GTX 285 OCX
Asus P6T Deluxe V2
BFG GTX 285 OCX
- jessestormer
- Contact:
I was wondering if anything became of this -- I'm trying to do something similar -- ie: get control of the thickness of rendering a spline as hairaoktar wrote: Sat May 14, 2022 7:17 amI'll add something like that if there's not really a way to convert tracer data to hairsrodney71 wrote:the idea came from seeing this control in Redshift. Rendertime splines is the only way to handle this efficiently with many particles
I can't seem to find a solution, for the sake of avoiding using geometry
EDIT:
I think I did figure this out. Using the C4D Hair object with a hair shader on it,
Guides tab: set the LINK slot to the spline you want to keep - root count, and length will auto update
Increase Segment count under guides tab
Hairs Tab: Root *as guides*
That should do it -- worked for me!
