IPR Render Logs
runkickshout
I have an issue where whenever I start the IPR for the first time at least one log window opens up, sometimes 3 to 4 (log attached). I then need to resend my scene to the IPR in order to get it working. If I forget to start the IPR before trying to render to picture viewer the whole program will also sometimes crash.
Can someone please explain why this happens and how to avoid it?
Thank you!
Please write to help at otoy dot com so we can investigate more deeply, thanks.
ciao,
Beppe
dprice
Did you figure out a resolution to this issue? I am encountering the same.
Devin
From which previous version the scene was built?
Have you tried to merge/copy-paste the scene into a new empty one, and rebuild both Kernel and Render Settings from scratch?
ciao,
Beppe
dprice
I am traveling atm but will review and test when I return. Thank you for the response.
runkickshout
I think this may be what the issue was! Did a quick test and it seems to have fixed it. I will report back if it happens again, thank you.
bepeg4d wrote: Fri Nov 21, 2025 7:19 am Hi,
ciao,
Beppe
