possible bug with exr hdr ?
dinosgr
Can you guys check the file i share as it display black and white when i put it as textured env ,ok this is just a part as my file is huge.
on https://drive.google.com/file/d/1Yzfz8yYEEqngAFX48itT7I2wAUKNYWdo/view?usp=sharing
If you look at it with LizardQ Viewer its fine https://www.lizardq.com/en/viewer/
Thanks in advance
Konstantinos
linograndiotoy
I've tried loading the image in Blender, Krita, and several other applications, and they all display it as a white image with a black stripe at the bottom.
dinosgr
If you lower the power in the node you will see the image.
the only thing is that it say tiled type and use the tiled texture node, but if i use that its all black.
well... only the lizard do some magic with it and display it as it should... weird
I think its a problem with the photo stops used when bracketing. or octane use the most overexposed like a 100 %, maybe it should default at the middle.
If you agree after check it , disregard... or at least check the defaults of power, I was going crazy with it
Thank you
Konstantinos
linograndiotoy
It´s not an "Octane" problem. It's a more general issue with this image and the way it is "interpreted" at the default Power 1 value when loaded.
If by Tiled Texture you mean Image Tiles (which is for UDIMs), and this is only one image of a whole UDIM set, it should work, as long as the images are properly named.
dinosgr
@linograndiotoy
But look at this jpg 3 programs 2 are fine, and one has the behavior of octane.
I am already in talks with the fastpicture viewer dev and he try to fix, maybe its a problem on those hdri files as you said, btw even the standalone has this behavior.
Take a look at the jpg I send you here as those 2 programs do stiching and manipulation of hdri or doing it from multiple exposure and they handle it the right way, dunno at the end no problem to dial the power down .
https://drive.google.com/file/d/1hWtEADU_PnZ6MLfQhCOy-HUTPE6-X2NI/view?usp=sharing
for listening
Return to “Blender”
