3dsMax_Win11_24H2_Path_Fix.bat
Elvissuperstar007
I made a simple script that will help you get rid of this problem.
:: A free script to fix the Windows 11 24H2 error,
:: due to which 3ds Max does not see user scripts, macros and plugins.
:: The script removes system/hidden attributes from AppData and Local,
:: and also automatically corrects paths for all installed versions of 3ds Max.
this bug in Windows 11 24H2 is due to the fact that Max in new builds uses useUserProfiles=1, and as a result, usermacros and scripts go to %APPDATA% instead of the local Max folder.
.bat actually:
Makes the AppData folder visible.
Backups usermacros to a separate directory.
Changes useUserProfiles=1 to useUserProfiles=0 in InstallSettings.ini.
Run as an administrator!
https://3ddd.ru/forum/thread/show/3ds_max_2024_v_novoi_versii_windows_11_24h2_problema#post1773399
@echo off
SETLOCAL ENABLEDELAYEDEXPANSION
REM === Remove attributes from AppData and Local folders ===
cd /d %USERPROFILE%
attrib -h AppData
cd AppData
attrib -s Local
REM === Search all installed 3ds Max versions and apply fix ===
set "BASE_PATH=C:\Program Files\Autodesk"
set "BACKUP_ROOT=C:\3dsMax_usermacros_backup"
for /d %%D in ("%BASE_PATH%\3ds Max*") do (
set "MAX_PATH=%%~fD"
set "USERMACROS=!MAX_PATH!\usermacros"
set "INI_FILE=!MAX_PATH!\InstallSettings.ini"
echo Found: !MAX_PATH!
if exist "!USERMACROS!" (
set "BACKUP_PATH=%BACKUP_ROOT%\%%~nxD"
xcopy /E /I /Y "!USERMACROS!" "!BACKUP_PATH!" >nul
echo usermacros backup done
) else (
echo usermacros folder not found
if exist "!INI_FILE!" (
powershell -Command "(Get-Content '!INI_FILE!') -replace 'useUserProfiles=1','useUserProfiles=0' | Set-Content '!INI_FILE!'"
echo useUserProfiles set to 0
) else (
echo InstallSettings.ini not found
echo All done. Restart 3ds Max.
pause
ENDLOCAL
3ds Max 24H2 Fix.rar
(654 Bytes) Downloaded 66 times
Jani
Thank Elvis,
it completely broke down my 3ds Max, I now have to run it as administrator, so I can only open scenes if I open a fresh Max, otherwise I get a shit ton of errors for missing files/plugins/dlls and what not. I also constantly have to re-do the UI because it resets to default.
Can you suggest a method to revert what you did?
Because I can't work like this I'm thinking of re-installing everything.
Cheers
i9 9920X, 64GB, RTX 2080Ti
Ryzen 1800x, 64GB, 2x RTX 3090
Return to “Autodesk 3Ds Max”
