Capture AOV driving me crazy
pacey84_1
I can't get a custom AOV to display even a simple red colour (it needs to show a gradient matched to the axis of the object, the red is to try and debug)
As you can see I get a red fringe on my custom AOV pass, so some data is being passed, but it should be solid red, not just out of focus fringes
Red fringes
Red fringes
Here is the geo
Geometry
Geometry
Here is the node setup with the capture AOV set to AOV 2
Node Graph
Node Graph
And here is the AOV manager showing the custom is set to custom 2
AOV manager
AOV manager
Finally, here is the beauty pass
The shader is an octane glossy material.
Here is an image showing that if I plug the red straight into the diffuse it works on the beauty:
As does the intended gradient
Please HELP its driving me crazy
jobigoud
Maybe you have a piece of glass or some other geometry between the camera and the object such that the object stays fully visible to the camera in the render but when isolated through the custom AOV it doesn't see it correctly.
pacey84_1
Thanks for your suggestion, I have cleaned out the scene completely to avoid any anomalies so there are no plains or lights, but the results are as above.
Ok, could you share the scene so we can have a look?
You can share it via Private Message if not sharable in public.
ciao,
Beppe
pacey84_1
Thanks Beppe, I have PMd you, let me know if you didn't get it.
