OctaneRender for DAZ Studio 2025.2.1 - 403 [STABLE]
Moderator: BK
BK
SiliconAya wrote: Fri Jun 27, 2025 6:07 am First off, thanks for the update!
I just got this crash while using this new version of the plugin and while access violation crashes are rather common in Daz Studio, this is the first I've had that lists octane.dll in a long time (years?), as there was a concerted effort to report and fix them all a while back.
At the time I was panning the camera, which doesn't really seem related to the crash, so not sure that helps.
Is there anything else that should be provided next time i get a crash or is this enough?
Hi SiliconAya ,
Thank you so much for reporting this.
We are unable to replicate the crash on our side.
Would you happen to remember the steps and was there any AOV enabled from the interactive viewport.
Cheers
Kind Regards
bk3d
BK
Hun73rdk_1 wrote: Sun Jun 29, 2025 8:21 pm Delete Render settings does not work under rendersettings manegement the button is grayed out what ever i try one or all selected
Hi Hun73rdk_1,
Thank you for the post.
Do you mean the Kernel?
It looks like we need to create a new one to be able to delete/change the rendersettings.
Please let us know !
cheers
Kind Regards
bk3d
BK
filipe_sheepwolf wrote: Mon Jun 30, 2025 11:07 am Awesome news! I'll comment if I find any new bugs.
May I ask if VDB/Volumetrics support is coming? It's lack of support is another thing that keeps forcing me to use Iray
Hi Filipe,
Thank you so much for the reminder.
We still do not have a timeline, unfortunately. Agree with you! Octane engine has supported VDB for a long time.
We have requested our developer to investigate and set the VDB support as high priority.
However, it totally depends on the existing bugs. We will keep updated on this.
cheers
Kind Regards
bk3d
Hun73rdk_1
BK wrote: Wed Jul 02, 2025 8:52 pm
Hi Hun73rdk_1,
cheers
What kernel those are render setting and octane keeps duplicating them if your not careful and if you load another scene the old one still persist.
But there is no fast way to delete them i used a ton of time on deleting due to the fact you cant use the delete button in that window
Join the Octane Daz Fan server for people that uses daz and octane https://discord.gg/wDzwC8tqAK
Hun73rdk_1
Replace all active maps does not seem to work anymore
Hun73rdk_1
Changing Image node from grayscale to RGB will make daz crash sometimes.
Adding diffuse node to a LayerGroup will make daz crash somtimes.
BK
Hun73rdk_1 wrote: Thu Jul 03, 2025 9:39 pm
Hi Hun73rdk_1,
cheers
Yeah, Kernels under render settings.
Have you tried deleting the `OctaneRender_settings.oczdb ` from the user data folder?
cheers
Kind Regards
bk3d
Hun73rdk_1
BK wrote: Mon Jul 07, 2025 9:40 pm
Hi Hun73rdk_1,
cheers
cheers
Those are stored in the scene file
Hun73rdk_1
Linking DOF to Daz camera will brake Octane and Octane will not respond to moving the camera but will change the DOF instead
BK
Hun73rdk_1 wrote: Thu Jul 10, 2025 3:17 am Linking DOF to Daz camera will brake Octane and Octane will not respond to moving the camera but will change the DOF instead
Hi Hun73rdk_1,
Thanks for the post.
Could you please share the steps to replicate this issue?
We are unable to reproduce it.
Cheers
Kind Regards
bk3d
Return to “DAZ Studio”
