does not convert correctly Vray-Corona to Octane
Elvissuperstar007
4442987.6308272005c51.rar
(79.05 MiB) Downloaded 116 times
Elvissuperstar007
color correct octane does not match color correct standard,
well and normal map does not convert
Elvissuperstar007
another file that converts poorly, artifacts and black spots appear on the model, I fixed it, but there is clearly a converter error somewhere, If I remember well, there was something wrong in the bump during conversion.
2758905.5e77e09500568.rar
(90.23 MiB) Downloaded 126 times
Elvissuperstar007
I checked this on other models, octane does not convert Color Correction correctly at all, it becomes light
paride4331
Hi Elvissuperstar007,
I'm noticing some potential issues with the gamma settings during the conversion process. It seems like something might not be working as expected, either in the way the conversion is handled or in the default values set in the corresponding window. I'm running a few tests before reaching out to the developers. Adjusting the albedo gamma to 2.2 definitely improves the outcome, but it doesn't seems to be not the only parameter affecting the problem.
Return to “Autodesk 3Ds Max”
