isolate node
HHbomb
I wanted to mimic the solo node in c4d.
As always I made a frankenstein style script but it works ( at your own risk )
I made a macroscript you'll find in "yoko" category ( I bind it to ctrl+alt+s key as I don't use incremential save )
Just select the node you want to isolate, run the script.
If your octane viewer is opend you can see the node ( map or noise or...) on your object
You can refine your setting then click EXIT.
If anybody can enhance the script he is welcome :-)
Better not to have Quick update mode on.
ISOLATEmap.zip
(1.02 KiB) Downloaded 156 times
remKa
Oooh I was thinking about that, very nice thank you, I'll test that soon !
AMD 9950x3D / RTX 4090 / RTX 3090 / 192 Go DDR5 / Win 11
http://www.remy-kerbiquet.com
HHbomb
Infortunately when the map is used several times it don't work... hope somebody ( neonZorglub ? ) can do far better :-)
Return to “Autodesk 3Ds Max”
