OctaneRender for HoudiniSolaris 2024.1.2.0 [Obsolete]
eh_studio
Hi there, I'm using Solaris version 2024.1.2.0, Houdini build 20.5.445, but just rendering in the standard SOP context, not in Stage. For some reason my AOVs are not being outputted. I'm working in ACEScg, saving as 32-bit EXR in DWAA or DWAB compression. When I bring the file into Davinci Resolve, the names of the AOVs show up, but the rendered layer itself is completely blank. I'm using the Open Image denoiser and the denoised passes are the standard beauty, then diff. direct, diff. indirect, ref. direct, ref. indirect, remainder. I also have shadow and post-processing passes. Any clues as to what's going on? I haven't had this problem with previous Octane Solaris versions or Houdini builds.
adrianr
adrianr wrote:Image
This is popping up on every program start regardless of which option you select. Wouldn't be a problem but it stops the rest of the program loading whilst it waits for an answer.
I've just noticed a farm machine has not actually been rendering anything for the last 30+ minutes because it's waiting for an input for this prompt. Please fix it.
Windows 11 | 14900k | 2 x 4090 | 96gb DDR5.
adrianr
I'm not going to check every single parm, but Render Geometry Settings still looks to be setting all parameters to default even when set to 'Do Nothing'. As far as I can tell none of the parameter operators work - they're all acting as if they're set to 'Set or Create'. I'm guessing this is a hangover from when this node did originally set everything on creation, but it seems only the interface was updated and not the core operation.
sick
Sweet!
Waiting for Linux build as well. Is there any ETA?
Linux | Geforce GTX780 | i7 2600K | 24GB
Return to “Releases”
