Plug in installation issues.
Houdini Integrated Plugin
spartan00j
Coming from the other side of the form. Making a jump from poser to Houdini.
I'm having issues with the plug-in installation. I have version 20.5.278 of Houdini. Is this version correct of the plug-in I should use (Octane_2024.1.2.0_Houdini_20.0.896_Studio+_Win64).
Because after installing I get these weird messages trying to open up octane plugin. See attachments
When I first opened Houdini
When I try to use Octane in Houdini
Screenshot 2025-01-10 160520.png (15.12 KiB) Viewed 9179 times
Also this is what I put in the houdini.env file at the bottom.
PATH = "C:\Users\spart\Documents\houdini20.5\Octane_2024.1.2.0_Houdini_20.0.896_Studio+_Win64/bin;$PATH"
HOUDINI_PATH = "C:\Users\spart\Documents\houdini20.5\Octane_2024.1.2.0_Houdini_20.0.896_Studio+_Win64;&"
HOUDINI_DSO_ERROR = 2
Thanks for your help in advance.
Win 11
Ryzen Threadripper 2950X
128GB RAM
RTX 3060 TI
ricky_otoy
Hi there, your Houdini + Octane versions need to match.
Please consider upgrading to a newer production build like Houdini 20.5.370.
viewtopic.php?f=102&t=84382
Alternatively, you will have to use an earlier version of the plugin 2024.1.01 for Houdini 20.5.278.
https://render.otoy.com/customerdownloa ... _Win64.zip
We only support the last production builds for 19.5 and 20.0 and the last 3 production builds for the latest 20.5
ricky_otoy
Also if possible, consider using a package instead of the environment variable.
Remove the environment var for Octane that you added then follow these steps.
1) Download the correct version of Octane to match your Houdini build
2) Extract plugin (wherever you are storing it)
3) Extract the batch into the root of the plugin
4) Run the batch and follow the prompts
Batch file to create the package (windows):
MakePackage_Octane.zip
(1.86 KiB) Downloaded 306 times
Return to “Houdini”
