OctaneRender® pre-Beta 2.4 (win x64) [OBSOLETE]
- Elvissuperstar007
- Contact:
and the second bug, it's with him, turning blue?
Last edited by Elvissuperstar007 on Mon Jan 17, 2011 1:50 pm, edited 1 time in total.
this version will be usefull for all that making archvis.... (sun/sky)
but those are..... .... just boring...
let me be archvis hater for just one day
i7 2600K + 2X gtx 580 + GTX 560 Ti + 8gbram + Win7 +
AUTODESK SOFTIMAGE 2012
www.behance.net/mlody47
- Elvissuperstar007
- Contact:
the animation is already checked, materials not fly! excellent
- EricDesign
- Contact:
i use this in job work with small 450GTS and dam is very slow right now and is freeze on small object, him not happy ;(
i try tonight in my home with 470GTX for watch the difference...
I'm not sure if its talked before.
I would like to use the lens shift to achieve bigger renders.
But I also would like to preserve my old camera settings.
Is there a way to save those camera settings in graph editor as a node?
if yes,
How should I create the node workflow to save different cameras
And how can I connect the current obj to a new render target node in order to bypass the preview configuration
Has anyone been using this kind of routine..?
Thanks.
if yes,
Thanks.
My Portfolio
I did the Benchmark using octane_22_benchmark.ocs
on my single 465 GTX card. Since I can see all my 352 cuda cores in both versions. I am using two monitors on my single card by the way.
It's nice to see a slight performance gain due to optimizations i suppose. Especially in directlighting.
Pathtracing with 16 max depth
v2.4
1.66 Megasamples/sec
3.17 fps
v2.3_v5
1.65 Megasamples/sec
3.14 fps
Directlighting 5_specular 1_glossy depth
v2.4
7.0 Megasamples/sec
13.35 fps
v2.3_v5
6.34 Megasamples/sec
12.09 fps
v2.4
3.17 fps
v2.3_v5
3.14 fps
v2.4
7.0 Megasamples/sec
13.35 fps
v2.3_v5
12.09 fps
My Portfolio
@Elvissuperstar007Elvissuperstar007 wrote:luminescent materials do not pass through the alpha channel! ((
I made it work man.
If you happen to make the opacity of the Emissive material to 0 (zero)
than you will see the alpha mapped shadow.
Its good to solve it without the need of a new release.
See below.
My Portfolio
That's a semi-useful hack. And if you need to see the emitter?oguzbir wrote:If you happen to make the opacity of the Emissive material to 0 (zero)
cgmo.net
cgmo.net
