Hi All
I am fairly new to Octane and have and issue I guess is related to object space and world space.
When I put a texture on an object it stretches when scaled and scale applied.
how to prevent that ?
or how to set world space this is my test test setup
Any comments appreciated
Texture streching with object
- interelectronix
- texture streching.blend
- (1.34 MiB) Downloaded 77 times
Hi, you need to redo UV mapping for this object or scale down (using 3d transformation) the axis that is stretching.
System – Windows 11
System – Windows 11
- interelectronix
Thank you for your feedback.
I have added the box projection and set it to word space but no change.
The reason I use the projection is not having to do the unwrapping on certain objects.
Do I really have to change the displacement height for every object and end up with multiple copies ?
Texture displacement needs properly unwrapped mesh. I does not work with any other projections other than UV projection.
System – Windows 11
System – Windows 11
- interelectronix
Manually unwrapping is impossible for us because we have CAD assemblies of hundreds of parts.
But I found this amazing software. Works perfectly fine for us.
https://meshmatic3d.com
Hope this helps
Hope this helps
Thanks for the software tip!
System – Windows 11
System – Windows 11
