Osl Texture node can't work in solaris octane material
Hydra Solaris (Legacy Plugin)
This plugin has been superseded by the Houdini plugin (2026.5.0.0 and higher)
Azure_CN
OctaneRender: 2023.1.3.1
Houdini Solaris: 20.0.724 py 3.10
Osl Texture node can't work in solaris, houdini console shows error:
Octane Error: Can't write float to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFEFE91A810)
Octane Error: Tried to access null node pin
But osl node can work in houdini ipr, the material was built in mat.
BK
Azure_CN wrote:OctaneRender: 2023.1.3.1
Hi Azure_CN,
Thanks for the report.
Could you please try with the latest RC13? OSL seems to work on our side.
viewtopic.php?f=141&t=83920
cheers
Kind Regards
bk3d
Return to “Hydra Solaris (Legacy Plugin)”
