mopgraph animation random color
Hello, i'd like to reproduce that effect, I started with a random effector with shader field but at the end of the animation I just want to reveal a logo. At that point, I blocked, can someone helps me please? I join you the final animation I need to reproduce and my C4D project.
- C4D Moograph Fields.mp4
- (10.71 MiB) Downloaded 1407 times
the animation in question: https://ibb.co/7XsYzK7
you can use an Octane Instance Color node, to get the colors from the MoGraph cloner in Render Instance, or Multi Instance mode.
Then use a Shader Field for coloring the clones as you like: cio,
Beppe
Beppe
in C4D Shader Field, avoid to use the Octane ImageTexture node, and load the bitmap directly in the shader slot.
ciao,
Beppe
ciao,
Beppe
