Hey, Aoktar
Till now I read we have 2nd and 3rd UVs capabilities!!!
Awesome!!! Very needed!!!
Regards!
Cinema4D version 2023.1.3-R6 (obsolete stable) 11.10.2024
C4D 2025.1.1 Octane v1.9 // Octane SA 2026.2, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, NVIDIA SD 595.79
Octane User since V1 Beta
That's a pretty vague request. If you can be more explicit in what you are trying to achieve, you might get better feedback. If you mean nodes with math functions that include exponents, take a look at the Math Unary and Math Binary nodes in the Custom Textures section.1026613912 wrote:Can you add a node to facilitate the creation of a black hole like effect, The nodes in redshift seem to be called power operations
Two issues :
1. Ripple C4D shader ignore Object and Particles fields. Strange but most of the C4D shaders works fine :
2. There is no way to change brush color and brightness while painting textures if this texture is used in Octane material. Brush is completely locked, even Eraser doesn't work :
Octane Texture Manager : Update List doesn't work ( there is need to reopen manager ), "Replace with" feature really should work only for selected images from list instead of all listed just like C4D Project Asset Inspector.
just forwarding this from FB (since user can not post on forums)
https://www.facebook.com/groups/OctaneR ... 366018891/
EDIT: Solved, C4D needed an update.
can't seem to get my Octane working in Cinema4D:
Macbook Pro M1 Max
MacOs: Ventura 13.6.4
Cinema 4D: 2024.2.0
OctaneRender: 2023.1.3_R3_OSX
Deleted the older 'xlib' versions and left the 'c4doctane-R2024.xlib' file, allowed Octane in the Privacy & Security section.
What am I doing wrong and what could solve this?
- 1026613912
In 2023.1.2R7, there is a problem with the ior map of OctUniversal and OctStdSurface1, and Falloffmap cannot work properly, but it is fine in 2022.1R8
- bug.zip
- (4.13 MiB) Downloaded 179 times
- marcus1070
- Contact:
I'm having a small trouble here.. is the 2024.4 particles colors not working with the motion blur?
both screenshots are from the same frame, no changes, just motion blur on/off latest plugin and 2024 version, drivers up to date..
- Win 10 Pro 64bit
- 64gb Ram
- RTX 3090
- RTX 2080
- Nvidia driver version: 516.94
- Cinema 4d r25
- Plugin version Studio+ 2022.1(r7)
http://www.marcusrizzo.com
- 64gb Ram
- RTX 3090
- RTX 2080
- Cinema 4d r25
Hi,1026613912 wrote:In 2023.1.2R7, there is a problem with the ior map of OctUniversal and OctStdSurface1, and Falloffmap cannot work properly, but it is fine in 2022.1R8
could you share screenshots from 2022.1?
My suggestion is to export to Standalone to see if you have the same behavior.
And if yes, post the question in Standalone discussion.
ciao,
Beppe
Motion blur is not supported yetmarcus1070 wrote:I'm having a small trouble here.. is the 2024.4 particles colors not working with the motion blur?
- 1026613912
OC can also achieve the effect of black hole distortion, I found a wayfrankmci wrote:That's a pretty vague request. If you can be more explicit in what you are trying to achieve, you might get better feedback. If you mean nodes with math functions that include exponents, take a look at the Math Unary and Math Binary nodes in the Custom Textures section.1026613912 wrote:Can you add a node to facilitate the creation of a black hole like effect, The nodes in redshift seem to be called power operations
- 1026613912
The black in the middle is the refraction affected by the falloffmap. In theory, the change of ior is similar, but on 2023.1.2r7, there is a problem with ior and the falloffmap does not change with the camera.bepeg4d wrote:Hi,1026613912 wrote:In 2023.1.2R7, there is a problem with the ior map of OctUniversal and OctStdSurface1, and Falloffmap cannot work properly, but it is fine in 2022.1R8
ciao,
Beppe
- bug.zip
- (2.79 MiB) Downloaded 136 times
