Hi all !
I recently tried to send an LW / Octane scene to a renderfarm (render4you), and we couldn't get the scene to render correctly.
The scene was packaged from my computer and loaded ok at the renderfarm. When rendered from my computer (no network), the scene looked perfect.
The problem at the renderfarm was that objects in the scene randomly disappear, depending on the node the scene was sent to.
To make things clearer, each render node was given 5 frames to render, but almost every set of 5 frames had an error : a random object was missing (not always the same !).
Here is what the result looked like (MP4 file) :
https://drive.google.com/file/d/19WUWcW ... sp=sharing
We tried almost every setting for network rendering, disabled multi-thread scene extraction, set the update mode to full-scene reload, nothing worked and the guy from Render4you (very understanding) was as baffled as I was.
Sidenote : the renderfarm used command line to manage rendering
Does anyone have an idea of what the problem is ?
