Aperture Rotation slider does not work
Forums: Aperture Rotation slider does not work
Sub forum for bug reports
Moderator: aoktar
C. RAM Capacity (i.e. 6 GB)
Postby speltrong » Sat May 04, 2024 1:32 pm
speltrong Sat May 04, 2024 1:32 pm
Win11, 4090 mobile, 64RAM, C4D 2024.4.0, Octane 2023.1.2-R7.
Universal Camera > Universal tab > Depth of Field section > Aperture Rotation does not work in the C4D plugin. It works in the corresponding Standalone app. Test files attached. Screenshots below:
Bokeh Test Standalone.ocs
(100.98 KiB) Downloaded 25 times
Aperture Shape Rotation.zip
(77.18 KiB) Downloaded 12 times
speltrong
Re: Aperture Rotation slider does not work
Postby aoktar » Sun May 05, 2024 1:29 pm
aoktar Sun May 05, 2024 1:29 pm
It's working as expected! Please try to reinstall your plugin, it maybe related to some wrong resource files.
Postby speltrong » Sun May 05, 2024 4:37 pm
speltrong Sun May 05, 2024 4:37 pm
Reinstalled - I'm now using 2023.1.3-[R2].
Still see the same behavior. Aperture rotation in the Thinlens camera type works ok. Aperture rotation in the Universal camera type does not.
ThinLens - Rotation OK
Universal - Does not rotate
Simplified file here with just one sphere and two cameras. If you look through the ThinLens camera, it rotates as expected. If you look through the Universal camera it does not.
Aperture Shape Rotation v02.zip
Simplified file. Two cameras showing the issue
(82.41 KiB) Downloaded 16 times
speltrong
Postby frankmci » Sun May 05, 2024 6:26 pm
frankmci Sun May 05, 2024 6:26 pm
aoktar wrote:It's working as expected! Please try to reinstall your plugin, it maybe related to some wrong resource files.
For what it's worth, I'm seeing the same behavior with OctanceC4D 2023.1.3_R2 under C4D 2023.2.1.
Thin lens camera aperture rotation working, but Universal camera aperture not rotating.
frankmci
Postby boxfx » Sat May 18, 2024 3:09 pm
boxfx Sat May 18, 2024 3:09 pm
I can confirm the bug. Universal cam aperture rotation does nothing, thinlens cam works fine
c4d 2024.4.0
octane 2023.1.3 R2
gf 4090
driver 551.86
boxfx
Postby aoktar » Sat May 18, 2024 7:48 pm
aoktar Sat May 18, 2024 7:48 pm
It's doing something else of what you think, but not noticable. But looks like parameter has different range and name in universal camera (like a rotation value -360 to 360). It's mistakely named on thinlens camera, should be "bokeh rotation".
Return to Bug Reports
Mon Jun 17, 2024 3:10 am [ UTC ]
