Cinema4D version 2023.1.3-R6 (obsolete stable) 11.10.2024
marshalartist
There is a problem with the Octane gradient node. It turns everything red that is fed into it when adjusted. Please see attached file
gradient.zip
(96.48 KiB) Downloaded 104 times
frankmci
marshalartist wrote:There is a problem with the Octane gradient node. It turns everything red that is fed into it when adjusted. Please see attached file
It looks like the Octane Gradient node is behaving as if there is an "invisible" red color chip on the left edge of the gradient and an invisible white node on the right. As a workaround for the moment, you can add a color chip to the far left and right, then it should work as expected.
Gradient bug work-around
It's a BUG because of my latest revisions. It is fixed on R2 build.
Amaterasu
How to fix the problem?
octane 2023.1.2 240425 052006.txt
(14.99 KiB) Downloaded 160 times
Amaterasu
Where can I find the manual.zip? I uninstalled all versions except 2024 and for some reason the octane did not appear, but on cinema 4D R26 everything works, I had the same problem with the stable build
Amaterasu
Update
octane 2023.1.2 240425 052539.txt
(3.31 KiB) Downloaded 115 times
SSmolak
Amaterasu wrote:Where can I find the manual.zip? I uninstalled all versions except 2024 and for some reason the octane did not appear, but on cinema 4D R26 everything works, I had the same problem with the stable build
Delete C:\Users\ YOUR USER NAME \ AppData\Roaming\Maxon\Maxon Cinema 4D 2024_A5DBFF93\prefs oct.dat file. and install Octane again. Last builds are for 2024 C4D version.
Amaterasu wrote:Update
Double check your install for double installs which causes . You looks like running previous build:(2023.1.2). Also try latest Nvidia drivers
Amaterasu
Yes, that's right because the latest version is simply not installed, I tried to do all the above points and it is on cinema 4d 2024.3.2 the latest version of octane is not installed, on cinema 4d R26 all stood up without problems.
The error did not go anywhere, I attach the log from cinema 4d R26 + octane 2023.1.3-[R2], thank you for your help!
octane 2023.1.3 240425 165513.txt
(4.74 KiB) Downloaded 109 times
stefano-dear
with old files the live viewer works correctly, but if I launch in render it always crashes :(
c4doctanelog[1].txt
(19.21 KiB) Downloaded 108 times
Return to “Releases”
