mograph color ignoring particle color data
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
boxfx
If I assign colors to mograph particles in c4d 2024.4.0, the colors are ignored by octane. Regular cloner with color randomiser works.
c4d 2024.4.0
octane 2023.1.2 R6
geforce 4090
driver 551.86
win 11
particle color.zip
(136.31 KiB) Downloaded 80 times
boxfx wrote:If I assign colors to mograph particles in c4d 2024.4.0, the colors are ignored by octane. Regular cloner with color randomiser works.
c4d 2024.4.0
octane 2023.1.2 R6
geforce 4090
driver 551.86
win 11
You are using new particle tools. It's not yet implemented, not sure why do you post as a bug it!?
if you set the MoGraph Cloners to render Instance, and use the Octane Instance Color node, instead of the C4D Color Shader, it seems to work as expected:
Here is the scene:
particle color_b.c4d.zip
(116.41 KiB) Downloaded 86 times
ciao,
Beppe
boxfx
I found something that doesn't work, so I posted it. I don't have your internal development map in front of me, for all I knew you've had access to the c4d particles beta for months and may have already implemented support for it.
boxfx
bepeg4d wrote:Hi,
Here is the scene:
ciao,
Beppe
Thankyou xx, this will let us start experimenting with particles until the official support is released.
Return to “Bug Reports”
