Hi Aoktar, the R7 doesn't solve the Solo problem, on R6 nothing is visible on Solo mode, on R7 all are visibile on solo mode, In addition, there is a serious stability problem when selecting a C4D interface layout, both for standard setup and personalized ones, C4D crashes immediately.It doesn't crash only on standart e startup layout.aoktar wrote:It will be fixed on next build, thanks!augdalmo wrote:Hi Aoktar,
Solo mode does not works on C4D R23, I have tried all plugins releases for Octane 2023.1.2
it works only on Octane 2023.1
Cinema4D version 2023.1.2-[R7] (Obsolete stable) 27.03.2024
Not reproducable here!augdalmo wrote:Hi Aoktar, the R7 doesn't solve the Solo problem, on R6 nothing is visible on Solo mode, on R7 all are visibile on solo mode, In addition, there is a serious stability problem when selecting a C4D interface layout, both for standard setup and personalized ones, C4D crashes immediately.It doesn't crash only on standart e startup layout.aoktar wrote:It will be fixed on next build, thanks!augdalmo wrote:Hi Aoktar,
SOLO is working well here also, can you record video for SOLO and crash issue?
Hi Aoktar, the R7 doesn't solve the Solo problem, on R6 nothing is visible on Solo mode, on R7 all are visibile on solo mode, In addition, there is a serious stability problem when selecting a C4D interface layout, both for standard setup and personalized ones, C4D crashes immediately.It doesn't crash only on standart e startup layout.[/quote]
SOLO is working well here also, can you record video for SOLO and crash issue?[/quote]
Here the video for Solo unSolo mode. It doesn't works.
the problem of crash was due to a not correct video driver installation, a clean installation solved the problem.[/quote]
- Cinema 4D R23.110 (RC) - [Untitled 1 _] - Main 2024-04-01 19-59-38.mp4
- Solo and un Solo mode
- (26.68 MiB) Downloaded 1431 times
@augdalmo,
No luck here! Could you please check you're running correct version of plugin? Show us your log outputs from Console window.
Hi Aoktar here the console contentaoktar wrote:@augdalmo,
Loaded Octane DLL:OctaneRender Studio+ 2023.1.2 version:13000200 SDK:2023.1.2
OctaneRender for Cinema 4D 2023.1.2-[R7] built for:230 C4D vers:23110
C4D:23110 comp:[Emanuele-WS] OS:[WINDOWS 64 BIT] Windows 10, 64 Bit, Professional Edition (build 19045) versType:10
CPU:[GenuineIntel, stepping 1, model 15, instruction family 6] speed:2.4 GHz numOfCpu:56Ht
Plugins:[houdiniconfig 3dquakersR23S24 addons advanced_render alembic Anima2LoaderR23 archigrass architron bitmapfilter bpexchange browser bugslife_client c4d23_bridge c4d23_bridge c4d23_bridge c4d23_bridge c4d23_bridge c4d23_bridge c4d23_bridge c4d23_bridge c4d23_bridge c4d23_bridge c4d23_bridge c4d23_bridge c4d23_bridge c4d23_bridge c4d_viewport_render c4dOctane-R23 ca ca2 cadexchange clothilde collada14 collada15 colorchoosergui compositing deltamush deployment dwg dwgobjects dynamics exchanges ExpansionPack1R23S24 ExpansionPack2R23S24 expressiontag fbx ForesterR23S24 GEOtexture_R23 getloglines_R23 gltf gorillacam goz hair HDRLightStudioConnectionC4D i_skp INSYDIUM_23 interop io_obj laubwerk_player metrics mkmodeler mocca model mograph motioncam motiontracker nbo nbp newman nlinshader nodeeditor objects onlineupdater otoy_cmd projectassetinspector python quadrangler relaxuv sculpt sculptbrushes shader sketch sky sla spacemouse splinemappingtool splinepatch substance teamrender terraformfx_23 thinking_parti...NVAPI initializing...
NVAPI Version: NVidia Complete Version 1.10
Nvidia driver version:551.61 [r551_40]
Loaded 175 osl scripts from dir:C:\Users\st\AppData\Roaming\Maxon\Maxon Cinema 4D R23_DBA5903C\plugins\c4doctane\res\osl_scripts
augdalmo wrote:Hi Aoktar here the console contentaoktar wrote:@augdalmo,
I'd advice you to try in a clean install without another plugins and default layouts. Somethings are bugging you there.
- dasmodular
Same here, Solo doesn't work.
It works for simple scenes. I can recreate this bug with a scene with 600 objects and no hierarchy.
Newest version of everything, Octane, C4D, OS, drivers.
Kind regards,
Denis
Kind regards,
Denis
Ok, give me the scene please! He is showing it on a simple scene. And we're not able to reproduce it in simple or complex scenes.dasmodular wrote:Same here, Solo doesn't work.
Kind regards,
Denis
- dasmodular
Please have a look into the attached file: I cloned a cube in a grid 10x10x10. When I select one of them and solo it nothing is rendered in the live viewer.aoktar wrote:Ok, give me the scene please! He is showing it on a simple scene.dasmodular wrote:Same here, Solo doesn't work.
Kind regards,
Denis
Kind regards,
Denis
- SoloLiveViewer.zip
- (113.61 KiB) Downloaded 82 times
Can I see a full screen capture of your C4D?dasmodular wrote:Please have a look into the attached file: I cloned a cube in a grid 10x10x10. When I select one of them and solo it nothing is rendered in the live viewer.aoktar wrote:Ok, give me the scene please! He is showing it on a simple scene.dasmodular wrote:Same here, Solo doesn't work.
Kind regards,
Denis
Kind regards,
Denis
