Cinema4D version 2023.1.2-[R7] (Obsolete stable) 27.03.2024
Anlv
eyeonestudio wrote:Octane Not Loading My Notebooke(eGPU 3090)
R6 is OK.
C4D console.....
CRITICAL: Method net.maxon.interface.assetlink.Create@874ec4c6e3a0aae not implemented by AssetLinkImpl (requested by file:///C:/Program Files/MAXON/CINEMA 4D 2024.2.0/plugins/c4doctane/c4dOctane-R2024.xdl64). [object_impl.cpp(908)] [objectbase1.hxx(537)]
net.maxon.asset.framework: Initialization of net.maxon.interface.assetlink [interface] failed.
CRITICAL: Method net.maxon.node.interface.nodeslib.CreateTemplateFromNodeSystem@3e4a2e59c095eb1a not implemented by NodesLibImpl (requested by file:///C:/Program Files/MAXON/CINEMA 4D 2024.2.0/plugins/c4doctane/c4dOctane-R2024.xdl64). [object_impl.cpp(908)] [objectbase1.hxx(537)]
net.maxon.nodes.framework: Initialization of net.maxon.node.interface.nodeslib [interface] failed.
Drawport API initialized
Framework : DirectX
Vendor : NVIDIA
Device : NVIDIA GeForce RTX 3090
Framework version: 12
WIN10 21H1 19043.1165
Processor Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz 2.20 GHz
Installed RAM 32.0 GB (31.9 GB usable)
R7 version requires Cinema 4D 2024.3.2.
3D Motion Graphics Designer / E-commerce Designer
13700K / 64GB / 4090 / PSU 1250W
eyeonestudio
I didn't see the instructions on the first page. Thanks. I will test with 2024.3.2.
I don't like C4D's repeated changes. Virtualization is unstable.
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
SSmolak
Can you add input selection to Switch node input pins ?
scaprendering
Vectron operators between mesh to SDF and vectron is being overridden by original mesh to SDF.
[youtube]https://youtu.be/JiTKmSBXDrA[/youtube]
@Ahmet can you please have a look ? This feature would be awesome and unique. :)
SDFBoole.zip
(82.46 KiB) Downloaded 157 times
SSmolak
LOD Convex Hull simplify display mode is transparent in Octane :
LOD_hull.zip
(322.76 KiB) Downloaded 110 times
SSmolak wrote:LOD Convex Hull simplify display mode is transparent in Octane :
scene?
scaprendering wrote:Vectron operators between mesh to SDF and vectron is being overridden by original mesh to SDF.
SDFBoole.zip
Voxel size of mesh_sdf is affecting the vectron. It's happening in SA also, so ask in SA forums.
SSmolak
Undo in node editor doesn't work if texture is dragged directly to image texture node. It works fine if texture is dragged to "edit controls" panel.
It switch to previous material in material manager instead.
node_undo.zip
(299.41 KiB) Downloaded 113 times
SSmolak
scene?
It looks that this is caused by UV opacity texture that doesn't work on Convex Hull custonm object :
LOD_0001.zip
(181.18 KiB) Downloaded 103 times
scaprendering
In standalone it works great, but in C4D the issue is that the SDF is being displayed twice, before the boole and after the boole.
Once the SDF has been booled, it should no connect back to group_1:
Expected Behavior: After applying the boolean operation (intersection or subtraction), only the resultant mesh (the modified SDF) should be visible in the render.
Actual Behavior: The original mesh SDF remains visible in the final render alongside the boolean result, leading to an incorrect visual outcome where both the original and modified meshes overlap.
This issue seems to be a bug as the expectation with boolean operations is to only display the modified mesh resulting from the operation, not the original unmodified mesh. It can be fixed by opening Octane node graph and manually disconnect the volume SDF fo group_01 but when Octane updates the scene it reconnects back.
Return to “Releases”
